valve lash woes, and other q's
Old Sep 14, 2010 | 09:49 PM
DROPT's Avatar
So i adjusted the valve lash with the motor good and hot, its got around 206k on the clock so i figured it was overdue. they were all tight apparently.
but i set the intake to .08 and the exhaust to .12 now it sounds horrible. but anyway, while tinkering with it i noticed this (look at pic)
what is suppose to be connected to that? ^^ its right above the starter if you couldn't tell.
Old Sep 15, 2010 | 05:17 AM
RustBucket's Avatar
Possible a part of the air injection system? Someone on here will know what it is...
Old Sep 15, 2010 | 05:19 AM
xxxtreme22r's Avatar
seems like that would be the place the reed valve would be but it's facing in an odd direction. is that an EFI or carbed truck? not sure but is that a 3.0L?
Old Sep 15, 2010 | 06:37 AM
BajaRunner's Avatar
I wonder about why its running horrible at stock valve lash specs. Why? Cause mine did the same thing. I went back and tightened them down .001" and it helps.
The only thing people have said on here is that the adjuster screws wear down, creating a false reading (they turn into hour glasses on the bottom rather than flat). Next time I'm feeling ambitious I'll take the valve cover off and replace them.
In fact, does anyone have the part # handy?
Old Sep 15, 2010 | 11:12 AM
DROPT's Avatar
it is a carbed 22r.
Old Sep 15, 2010 | 11:19 AM
gonna go look at mine, but the only thing I remember under the intake like that was the reed valve, but the hoses run forward and back not pass to driver like that.
Old Sep 15, 2010 | 12:10 PM
DROPT's Avatar
thanks man i would really appreciate it, ive been searching the internet for days trying to figure out what it is
Old Sep 15, 2010 | 12:22 PM
Man I do not have that thing there. In the process of uploading some photos.
Old Sep 15, 2010 | 12:27 PM
not the best photos in the world, crappy camera but here you go. In the last photo is the only thing I think that thing is but it was either relocated or just in a different spot because of year difference.
Old Sep 15, 2010 | 12:46 PM
DROPT's Avatar
what year is yours? ill go out there later and take a better look at mine, i guess ill have to pull some things off just so i can get a good look at it, i cant see it from underneath the truck
Old Sep 15, 2010 | 12:53 PM
1987 in my sig.
potatopants
Sep 15, 2015 06:26 AM
LotOMiles
Sep 14, 2015 11:45 PM
Streetrod19772000
Sep 10, 2015 06:22 PM
Boomer8404
Sep 10, 2015 09:01 AM
idadan208
Sep 7, 2015 09:06 AM
