22r can i use carburated in a fuel injection
alright guys i found me a motor on problem is its not the FI...the guy told me that it will fit and all i have to do is bolt up the intake off my motor and it will work.....is this true.. thanks fellows
in my research i can only say that this is highly debated so i don't know if i should pay these shade tree mechanics to mess with the cam or not.....if it is different how much of a difference will it make in the engine
ok guys update on what is happening with my truck.....the motor i put in was a carborated out of an 85. i research and everything was suppose to work well got motor sat in and started bolting the rest of the stuff up and in intake was different. so we said we would just swap heads with my other motor. so we removed the head and to everyones suprise the dadgum pistons are different. the broke motor has flat tops and the other has the round pistons on it. so now i guess im just SOL. 300 out on this junk motor and 400 out to have it installed.......not having a good day.
pre 86 the block and head are slightly different and the 86+
only way i think i can do it is to change it to a carb......i found another one going to look at it after lunch.......anyone need a 85 22r motor....i don't
oh well i guess lesson bought.....wife is gonna kill me when she gets all these bills
what do you plan on using the truck for? at this point as you said you are already in like 700 bucks. the cheapest/easiest route would be run a carb instead of efi. did the motor not come with the carb or intake?
its for sale make me an offer. i don't need it unless im gonna make a suped up go cart or something.....don't know how you would get it unless your close
