22re Engine will not stay runing
Old Sep 18, 2010 | 02:59 PM
tlpcolorado's Avatar
Bought a 86 4runner that had been sitting for 2 years just could not pass up the price, Replaced the fuel pump and filter fresh fuel got it to start and stalls checked all the relays and they checked out, can hear the pump working with the key in start. Acts like no fuel after inital start? Don,t know if ECM or something else? I know that EFI system is designed to stop without oil pressure or signal from alternater ,should start there or go to ECM. Thanks for any input.
Old Sep 20, 2010 | 11:10 PM
thook's Avatar
You did check the circuit open relay (fuel pump relay) and it was definitely fine? Then, possibly, the fuel pump switch in the airflow meter has gone out. Check out this link about 1/3 of the way down the page:
http://www.4crawler.com/4x4/CheapTri...shtml#FuelPump
Old Sep 21, 2010 | 07:59 AM
thook's Avatar
Wait a minute.......you can hear the fuel pump running? Is this with the key to ignition and motor not running? How long does the pump run with the key to ignition? It should only run for a couple of seconds in this situation. So, if you turn the key and the pump only runs for a few seconds then quits, that's normal. It's not indicative of "no fuel after initial start up".......if that's what you're wondering.
Therefore, jump the fuel pump tests connector illustrated in the link I posted and see if will start and stay running. If not, what razed said could be the problem.
Old Sep 21, 2010 | 08:00 AM
thook's Avatar
Pouble dost.......
Old Sep 21, 2010 | 12:24 PM
Flash319's Avatar
According to the wiring schematic the fuel pump only comes on when the air flow meter sees air moving. The pump only comes on when cranking and when running.
I would check your COR relay and your AFM. Do like Thook said and jumper to eliminate your pump.
Old Sep 21, 2010 | 01:24 PM
thook's Avatar
The pump runs for a few seconds to restablish pressure in the rail....initially. But, I guess that's only when the key is in STA position and not IG? My bad. I guess I'll have to go over the materials again to be sure. Thanks for pointing that out, flash.
Old Sep 21, 2010 | 01:27 PM
merfal's Avatar
My 88 was like that when I first bought it. It would start for a split second and stall. It would do that until I could get it running long enough for the engine to warm (aprox five min of trying to start it with immediate stalling). It was the coolant sensor; I replaced it and all was well.
Old Sep 21, 2010 | 04:08 PM
bigliltruck's Avatar
check to see if the flappper inside the afm is stuck
Old Sep 21, 2010 | 08:27 PM
Ok quick update, afm is ok tests out perfect. can turn key to start without depressing clutch and hear fuel pump. Removed all old gas and put in new. re-checked both relays and they check out. Just ordered new injectors, Fuel is pumped into fuel rail and cold start injector but does not seem to be getting into motor, i am down to injectors or ecu?
Old Sep 21, 2010 | 09:21 PM
thook's Avatar
Well, after sitting for two years? Could be the injectors. Are you saying the cold start injector is pumping fuel into the manifold? As in, it's definitely working? IF so, seems that would be clogged if the injectors were. But, who the hell knows. Pull the ECU cover and see if maybe the ECU's corroded at all. If not, then you can run a resistance or voltage test on the drivers. Then again, you could test for voltage at the injectors just as easily.....if not easier. Noid light works, in that case.
Colington
Mar 8, 2020 09:51 AM
Doug4320
Mar 24, 2018 10:11 PM
steve miller
Oct 10, 2015 01:40 AM
crashburnoveride
Aug 28, 2015 09:20 PM
bryan34w
Jul 6, 2015 05:53 PM
