Odd electrical issue
Old Sep 17, 2010 | 04:41 AM
UKrunner's Avatar
'91 4Runner 4x4 auto with swapped '98 3.4.
At idle if I put it into reverse the battery voltage drops, lights dim. Fair enough. However, if in reverse and if the power windows are up and I press the switch to roll them up, the battery voltage increases and lights get brighter.
Head lights, turn signals even the heated rear window dont have anything like the voltage drop the reversing lights do. And the power windows thing is just weird.
Any ideas?
Old Sep 17, 2010 | 06:41 AM
aviator's Avatar
Sounds like you have a gremlin... odd is definitely the right term...
Old Sep 17, 2010 | 09:03 AM
thook's Avatar
I'm only at the novice stages of understanding chassis electrical issues, but maybe this site will help you. Read whatever articles seem relavent:
http://www.autoshop101.com/
Old Sep 17, 2010 | 09:10 AM
thook's Avatar
A very novice guess here.......
The charging system is supposed to generate enough extra voltage to offset voltage load where the battery cannot suffice. Case in point, chassis electricals. Seems to me, if the voltage is spiking like that, maybe the regulator is overcompensating somehow or you're getting voltage bleed when the window switch is activated.
Old Sep 19, 2010 | 02:03 PM
aviator's Avatar
I agree hook a voltage reg issue sounds like a possible ans.
DeathCougar
Apr 1, 2018 11:29 PM
coryc85
Sep 9, 2015 06:24 AM
v_man
Jul 23, 2015 04:01 PM
Poncho0206
Jul 10, 2015 06:21 PM
AaronM
Jul 8, 2015 07:15 PM
