22RE Inner Fender Replacement
Old May 16, 2021 | 04:39 PM
ToyotaVW's Avatar
Hey folks, looking to replace the inner fender on the truck I just bought, 1991 Extra Cab 4WD Manual Trans with a 22re. The front left quarter got crunched, took out fender, inner fender, hood, rad core support, among other things. I have sourced everything aside from the inner fender. Toyota Part No. 5370289252
Toyota says they are discontinued, but I wasn't sure if anyone knew of some aftermarket stuff, or should I get salvaging?
Cheers!
Old May 26, 2021 | 05:26 AM
13Swords's Avatar
5 Year Member
A quick search yielded this little tidbit of info: "Interchangeable with 5370289252". Searching that number I came up with an available part here: https://parts.lakelandtoyota.com/p/T...370289252.html
Since it's interchangeable and available, you should be able to get this thru any Toyota dealer, or even online. I only showed the Lakeland Toyota listing above because I've dealt with them before and had no problems with them, but I'm sure you could find it elsewhere.
Old May 28, 2021 | 02:09 PM
ToyotaVW's Avatar
I performed the same search and got a lot of "Discontinued" notes for this apron sub-assembly. Strangely enough, the only dealers that I can seem to find that have stock are in Florida. Just debating whether I want to spend that much money to have it shipped up here across the border.
KOBZ
May 10, 2012 08:15 AM
Sanface
Oct 17, 2009 07:03 PM
fiend
14
Apr 27, 2005 08:13 AM
ranma21
30
Apr 18, 2005 06:57 PM
