Rough Idle with Brakes
Old May 24, 2021 | 06:34 PM
swampedout's Avatar
5 Year Member
So I havent gone through all of my vacuum lines and idle control valves, but the truck idles nice almost all the time until I drive it then use my brakes at a light. The idle will drop down to 500 or below sometimes. Once I noticed it was with the brakes, I tested it and pressed in the brake pedal5 or 6 times in a row and each time the idle dropped 10 or 20 rpms.
Any help on this?
Im going to go through brake booster vacuum lines this weekend.
Old May 24, 2021 | 07:15 PM
84sr5yoty's Avatar
Pull a vacuum to the line of the brake booster. It should hold perfect vacuum indefinitely. It sounds like the internal diaphragm of the brake booster is leaking.
Old May 24, 2021 | 08:37 PM
Hound Dawg's Avatar
5 Year Member
With the motor off, the brake pedal should get really hard to push after a few presses. Keeping your foot on it and starting the motor, it should release a bit. Check the check valve too
shem
Old May 25, 2021 | 04:11 PM
swampedout's Avatar
5 Year Member
Ok, Ill give it a look this weekend. thanks
Keener
Jan 24, 2019 02:34 PM
greencactus3
Jun 12, 2011 06:29 PM
MID SIZED BOSS
Aug 9, 2010 09:42 AM
lukeman970
Jan 26, 2010 03:40 PM
bretthayes
Oct 25, 2007 04:03 PM
