91 4runner, no 4wd
Old Jan 31, 2016 | 03:38 PM
Phillip Allen's Avatar
91 4runner, no 4wd
trying out the 4wd on my new to me 91 4runner v6. transfer case goes into low and hi, but the light in the dash doesn't come on and the front diff doesn't engage. any ideas?
Old Jan 31, 2016 | 08:16 PM
Chaser Johndoe's Avatar
auto hubs or manual hubs? t case cable good?(if equipped) axle disconnect work?(if equipped) auto trans or manual trans? (yes it matters on what type of t case you have)
Old Jan 31, 2016 | 10:34 PM
Manual transmission, auto hubs, not sure on the rest. Don't think there's a cable or disconnect.
Old Jan 31, 2016 | 11:08 PM
wyoming9's Avatar
Red face
I think you mean to say you have the ADD system.
Then maybe someone just removed the locking hubs and bolted on drive plates
Was there a reason you didn`t check this before buying ??
Like maybe it came in a big box??
Are the electrical and vacuum parts installed on the truck??
Old Feb 1, 2016 | 05:41 AM
could you get add with a manual? I've only seen them on auto equipped yotas. if he is supposed to have lock outs that means no disconnect on the axle. if thats the case means the t case has issues.
Old Feb 1, 2016 | 06:55 AM
scope103's Avatar
First figure out if you have ADD (Automatic Differential Disconnect, not the other kind). Does your front differential look like this? (two vacuum lines, and wire to a switch)
The switch is what operates the light; you put it into 4wd at the transfer case, a switch in the transfer case works a pair of VSVs on the right apron (under the hood), which switches the vacuum, which engages the ADD, which THEN closes the switch and turns on the 4wd light.
Old Feb 1, 2016 | 07:28 AM
millball's Avatar
Manual tranny trucks were equipped with ADD too.
My '95 5 speed Runner has ADD, but I installed locking hubs as well, to stop the front half-shafts from turning when in 2WD.
Old Feb 1, 2016 | 07:34 AM
RJR's Avatar
RJR
ADD was available on both manual and auto transmissions, starting in 1990.
Old Feb 1, 2016 | 02:31 PM
really appreciate your input guys, will take a look at the diff when the snow melts. lol
irv
Dec 21, 2021 12:38 PM
9322rerunner
Dec 15, 2015 10:14 PM
DonHagen
Nov 30, 2015 08:17 AM
82yodahickman
Nov 28, 2015 08:00 PM
dropzone
Nov 17, 2015 08:53 AM
