Strongest Clutch Upgrade 86 4runner Expedition build
Old 02-08-2016, 11:39 AM
Nippon_surf's Avatar
I need to replace my clutch ASAP, and want to upgrade flywheel and any other components at the same time. Any suggestions of brands that will best accommodate more weight/bigger tires/trailer towing. I'm currently looking over all others builds. Thx
Old 02-08-2016, 12:34 PM
MudHippy's Avatar
Marlin Crawler HD clutches.
Old 02-08-2016, 02:28 PM
muddpigg's Avatar
Originally Posted by MudHippy
X2, I'd ask them if whose bearings they use. Don't want a premature bearing failure in the middle of nowhere is not the same as premature bearing failure 10 miles from the house coming home from work.
Old 02-08-2016, 05:19 PM
millball's Avatar
Clutch and appropriate flywheel made for turbo models are tougher
Pressure plate and disc are larger diameter, so correct flywheel is necessary.
Old 02-09-2016, 12:27 AM
wyoming9's Avatar
Red face
I would worry more about hydraulic failure then the clutch hard parts.
One can nurse a failing clutch quite a distance.
Now if your talking enough torque in the engine to just twist the center out of the clutch that is a different story.
Then different climates one looks at different things in a build of this type.
Old 02-09-2016, 05:21 AM
MudHippy's Avatar
I just realized LCE's in the clutch game now. Interesting...
Old 02-09-2016, 07:44 AM
muddpigg's Avatar
I think they got in bed with trailgear.
Old 02-09-2016, 09:26 AM
wyoming9's Avatar
Red face
Wow I hope that does not hurt Trailgear
Old 02-09-2016, 09:42 AM
MudHippy's Avatar
It might. Since LCE's got the stronger 2100 lb. pressure plates. Which are supposedly stiffer than stock...
Wait...where the hell are we going with this?
Old 02-09-2016, 04:44 PM
Dezert_Yota86's Avatar
Just installed the Marlin crawler clutch a while back been happy with it so far!
Old 02-09-2016, 06:47 PM
I might order from LCE tomorrow, the clutch kit with the 30lb flywheel. I need to repair asap. I would replace master/slave also. Has anyone used LCE? Is it rebranded Trail Gear?
Old 02-09-2016, 09:21 PM
muddpigg's Avatar
LCE looks to have a bunch of their own stuff but looks to carrier TG SAS kits perhaps other stuff too. LCE is really proud of their assembled difs!! Their clutch kits don't look like TG kits.
Old 02-10-2016, 08:44 AM
Muddpigg... You are down in SA? That's my destination from Montana after I get a new clutch installed! Now I'm looking at stock clutch Stay tuned...
Old 02-10-2016, 09:02 AM
muddpigg's Avatar
Left SA last July currently enjoying the cold and snow of up state NY. Some reason wasn't able to change location. Traffic in SA sucks!!
ak4rnr
05-13-2016 07:52 PM
captainslow
02-08-2016 09:11 PM
captainslow
02-08-2016 09:10 PM
DirtRoad93
02-06-2016 04:17 PM
elaketiger
01-30-2016 06:44 AM
Quick Reply: Strongest Clutch Upgrade 86 4runner Expedition build
