Speed Sensor Location
Old Aug 9, 2013 | 03:04 PM
gibbonsballer10's Avatar
92 4x4 22re 5 speed. Speedo stopped working and was wondering where the speed sensor is located. Any help is greatly appreciated, thanks.
Old Aug 9, 2013 | 04:31 PM
milkybar's Avatar
Passenger side rear of transmission, follow the cables.
Old Aug 9, 2013 | 06:23 PM
scope103's Avatar
I think you mean rear of the transfer case (with a two-speed transfer case, it doesn't do any good to use the speed sensor in the transmission for the speedometer).
I believe the '92 has the electronic sensor, but if you find a speedo cable instead, you don't.
Old Aug 9, 2013 | 06:38 PM
INFINITY's Avatar
toyota used 2 kinds of ele speedo sensors. or body/wheel drive specific speedo cables. rock auto might have a cable.
Old Aug 12, 2013 | 05:47 AM
MudRunner92's Avatar
There is also a speed sensor inside the instrument cluster
Old Aug 12, 2013 | 06:21 AM
scope103's Avatar
Good point. But this only applies to the cable-driven speedometer. If you have the electronic VSS1 on the transfer case, that replaces the reed-sensor in the cluster.
Mine ('94, 4x4) has the electronic sensor. I don't know which years/models that applies to.
Old Aug 13, 2013 | 04:50 AM
92-94 are Electronic.
Old Feb 10, 2025 | 10:05 AM
noah korman's Avatar
On my pickup witch is a 95 I think there are 2 speed sensors located in the transfer case and top of the transmission. I think 92 was when they switched it to electronic speed sensors.
Does anyone know how to remove the one on the transmission it is giving me some trubble.
taller1
Nov 13, 2018 02:34 PM
montanatruck
Feb 26, 2017 07:07 AM
wilbertd
Jul 6, 2015 07:39 AM
karbin
Jul 5, 2015 11:37 PM
