Blue/Yellow wire - radio battery - no power
Old Aug 25, 2013 | 07:56 PM
punchy11's Avatar
I've got an 87 4runner SR5. Working on wrapping up a lot of work and ran into a problem trying to hook up my radio. Checked the ignition power and ground and they are good, but Im getting nothing from the battery power wire (Blue with Yellow stripe). This should be hot all the time, correct? Also checked the cig lighter to be sure it wasn't the fuse... it was not. So my question is this: where does the blue/yellow wire route to? I see it runs below the gauges toward the fuse box, but I lost it there. I want to chase this down but if it doesn't work out I will just run a new hot line.
Thanks in advance for any help.
Old Aug 25, 2013 | 08:06 PM
Sturmcrow's Avatar
Pretty sure the cig lighter and constant radio power are on different fuses, since the cig lighter does not work with the ignition off.
Inside the fuse cover there should be a diagram that will tell you which fuse goes to the radio. Check it out.
Old Aug 25, 2013 | 08:27 PM
punchy11's Avatar
Yeah... I guess that makes sense. Ill check it out in the AM.
Old Aug 25, 2013 | 11:09 PM
wyoming9's Avatar
Red face
That circuit is powered by the hazard /horn fuse .
It splices into a Green / White wire
Old Aug 26, 2013 | 07:06 PM
punchy11's Avatar
You got it WY. Thanks a lot for your help. Now I have tunes.
Old Aug 26, 2013 | 11:34 PM
wyoming9's Avatar
Red face
Your Welcome!!
Sleaker
Aug 26, 2020 06:03 AM
jasonty
41
Dec 23, 2018 01:00 PM
Johntom240
7
Jul 13, 2015 12:18 AM
skoti89
Jul 8, 2015 12:05 AM
colinmil
Jul 6, 2015 04:03 PM
