Need help with crack on dash!!!
Old Aug 16, 2013 | 05:14 PM
94toy22re's Avatar
i have a 1994 wich has a extra trim piece around the gauge cluster and a/c vents, the trim piece had two cracks a few inches apart. while going down the road the other day it completely separated from the dash. i went to Harbor freight after to work today and bought a plastic welder and tried to fix it. Now every time i fix one area another piece falls off. i have checked car-parts.com and ebay looking for that dash piece but no luck and theirs only a few whole dashes nearby and their either cracked or $400
Anyone know what the piece is called and where to find one or a whole grey dash for a reasonable price?
Old Aug 16, 2013 | 06:53 PM
RSR's Avatar
RSR
Take a picture and contact Toyota scrap yards or do the rounds at local pick and pulls and yank one out yourself. Usually it's the top part of the dash that cracks, so you should be able to find some.
And the part is available btw. You just need to navigate through online *Toyota* parts catalogs. Pretty easy to do with a couple second search.
Part #s:
5541135040 ; 5541104010
And if this isn't what you need, you can start a new search w/ your vehicle info: http://www.toyotapartsoverstock.com/...541135040.html
I like ToyoDiy.com for looking up vehicle specific parts by vin and then try searching using both full number and number with dash (different online dealers keep part #s differently so do both to find lowest $).
Old Aug 17, 2013 | 04:12 PM
oldblue's Avatar
i feel your pain. mine developed a crack, pulled away from the cluster, and finally i removed the whole thing. only bad spot in my interior. those things aren't cheap!
pickle6415
Dec 25, 2015 07:34 PM
Obmi
Nov 24, 2015 11:37 AM
Streetrod19772000
Sep 10, 2015 06:22 PM
zz_denis
Sep 6, 2015 03:43 PM
May-39
Sep 6, 2015 01:05 PM
