OBD I help on 1993 4x4 pickup
Old Aug 23, 2013 | 04:16 PM
jo3phresh's Avatar
hey all,
My check engine light is on. When I check the OBD1 check engine procedure to place a jumper from TE1 to E1 and then turn on the key to the on posistion the check engine light just remains solid - it does not blink to give me what the error code is. Any suggestions what the problem is? I have tried using a paperclip and a piece of copper wire, still with no luck.
thanks for your feedback!
Old Aug 23, 2013 | 05:32 PM
jo3phresh's Avatar
Ok, so i finally was able to pull the code. I got a code 21. which is
CODE NUMBER 21
System: Heated oxygen Sensor Signal
Malfunction Indicator Lamp: ON
Diagnosis: Open or short in heater circuit of heated oxygen sensor for 0.5 seconds. or more. At normal driving speed (below 60 mph and engine speed is above 1,700 rpm), amplitude of heated oxygen sensor signal is reduced to between 0.35 - 0.70 volts continuously for 60 seconds or more. 2 trip detection logic only.
Trouble Area: Open or short in heater circuit of heated oxygen sensor, Heated oxygen sensor heater, Open or short in heated oxygen sensor circuit, Heated oxygen sensor, ECM
any ideas on how i would go about fixing it?
Old Aug 23, 2013 | 06:07 PM
jb451's Avatar
Sounds like your 02 sensor is just bad.... Have you replaced it lately? Its cheap enough, i think 40 bucks off of rock auto.
Old Aug 23, 2013 | 07:46 PM
scope103's Avatar
You've run two results together. The second half ("At normal driving ...") is in "test mode" only.
But the answer is probably as jb451 says; you've got an open in the O2 sensor heater. For the $40 it is probably okay to replace it on spec; they don't last forever.
But you can get this code with a wiring problem (notably if you're running an "universal" sensor with a hand-spliced connection -- stay away from those.) You can test the heater in the O2 sensor if you are so inclined. http://personal.utulsa.edu/~nathan-b...01heatedox.pdf
Old Aug 24, 2013 | 06:16 AM
Neeaar's Avatar
severed wire
I got a code 21 and found a severed wire when I inspected the O2 sensor. I'm replacing the sensor anyway because I have no idea how old it is and I'm having other running problems. But the code 21 was from a severed wire in my case.
Old Sep 9, 2013 | 05:46 PM
jo3phresh's Avatar
so I say it safe to assume it was in fact just a bad o2 sensor. Went to a greedy junkyard and pocketed a couple o2 sensors and put them under the torch and voltmeter and replaced the broken one with one that works and the CEL has not returned.
Old Sep 9, 2013 | 06:53 PM
Kiroshu's Avatar
Good Deal
mskalmus
May 28, 2017 07:51 AM
MTLroadierunner
Jul 15, 2015 12:58 PM
colinmil
Jul 6, 2015 04:03 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
zd92655
Jul 5, 2015 04:25 PM
