3vze TPS voltage check VTA-E2.
Old 06-07-2009, 06:59 PM
pdebruic's Avatar
Hi,
So I'm messing with my TPS and the IDL-E2 works properly but the VTA-E2 resistance check is off. The FSM range for the VTA-E2 test is "0.47 - 6.1kOhm" Its my understanding that that means 470 Ohms to 6100 Ohms. Or does it mean 0.47 Ohms to 6100 Ohms? My VTA-E2 resistance is 29 Ohms. Does that mean I need a new TPS? At WOT it is in the recommended range. It does not drop the rpms when I put the jumper in from TE1 to E1. The timing wanders around 10 deg BTDC +/- 1 deg.
If the TPS is OK, what should I check next?
Thanks!
Paul
pdebruic's Avatar
Also, it seems to be dieseling a bit after shutting off the ignition. Everytime.
Old 06-07-2009, 11:59 PM
abecedarian's Avatar
have the timing set properly?
Old 06-08-2009, 06:08 AM
pdebruic's Avatar
Yes the timing belt is right. I can't adjust the spark advance. It is about 10 btdc but moves around. Does that mean it's time for a new tps?
smthwsn357
12-04-2023 02:08 AM
Gone Fission
01-12-2023 10:34 AM
chuckross1957
06-28-2019 10:19 PM
jetpilot
08-15-2015 06:48 AM
MTLroadierunner
07-06-2015 12:17 PM
Quick Reply: 3vze TPS voltage check VTA-E2.
