how to get air out of coolant lines?
Old Jun 3, 2009 | 11:00 AM
yoda84's Avatar
i need to know how to get the air bubble out of coolant line cause i took off my TB and i bealive i have air in coolant lines.....
Old Jun 3, 2009 | 11:04 AM
fillsrunner4's Avatar
remove the radiator cap turn the truck on and the heater on hi. give that a try
Old Jun 3, 2009 | 11:05 AM
toyota4x4907's Avatar
What engine?
With the 3VZ-E, I believe there is a bleeder valve.
With the 22re, you have to run the engine with the radiator cap off and the front of the vehicle elevated (to get best results)
Search for procedures
Old Jun 3, 2009 | 11:07 AM
yoda84's Avatar
3vze
where would this bleeder valve be...
Old Jun 3, 2009 | 11:56 AM
DupermanDave's Avatar
Why do you have to have the radiator cap off? Isn't there an overflow hole in the top neck of the radiator that will allow air to escape and blow it into the overflow tank? (this is for the 22re)
Old Jun 3, 2009 | 12:08 PM
The cap is under pressure thats why theres a spring and plunger on it. that hole is not for air to escape
Old Jun 3, 2009 | 12:40 PM
Lummpus's Avatar
I just flushed my system the other day. I parked it up on ramps and ran it up to temp with the cap off. it puked out a bunch of air and a little coolant. I had to rev it a little to kick out some of the air thats when the coolant puked out so make sure you have a drain pan under it .
Old Jun 3, 2009 | 08:44 PM
RobD's Avatar
You have to get the front end as high as you can. I parked on the uphill grade of my driveway, with the front tires up on ramps. Leave the cap off and be prepared to add coolant to the rad as it burps out the air.
It will take a while. Be patient.
the1998sr5
15
Jul 14, 2020 08:35 PM
Logz808
Jul 26, 2015 07:09 AM
itzmywife's
Jul 25, 2015 04:55 PM
ryerye13
Jul 14, 2015 08:27 AM
skoti89
Jul 8, 2015 12:05 AM
