Pinion seal fixed but still leaks
Old Jun 3, 2009 | 05:30 PM
AiNoKeA_808's Avatar
Pinion seal fixed but still leaks HELP!
So i had a pinion seal leak and just changed it out and its still leaking. not as much but still leaks. Before it leaked pretty bad to where it sprayed everywhere under my truck. Any suggestions on why its still leaking??!!??!
Old Jun 3, 2009 | 06:21 PM
jasonbrink's Avatar
My first and only guess is:
Your breather is plugged up. That may have been the problem all along, it's pretty common. Take it off and clean it.
Jason
Old Jun 3, 2009 | 11:07 PM
Jason
forgot to mention that. I did clean the breather. that was the first thing i did before i changed out the pinion seal. SOMEBODY HELP!!
Old Jun 4, 2009 | 12:31 AM
raydouble's Avatar
Was the pinion yoke worn like this one? (Not Toyota yoke)
The other thing I was thinking was the spring could have popped out of lip of the seal.
Old Jun 4, 2009 | 07:41 PM
im not sure about the pinion yoke. Could a worn pinion yoke cause my rear end to leak even with a new pinion seal? and what do you mean by pinion seal spring?
Old Jun 5, 2009 | 08:01 PM
nobody has any other ideas on why its leaking still?
Old Jun 5, 2009 | 08:03 PM
tc's Avatar
tc
Because it's not fixed.
Old Jun 5, 2009 | 08:12 PM
lol thanks for lots of help
Old Jun 5, 2009 | 09:09 PM
tidogardner's Avatar
I had that issue and it was because the seal I had first purchased was a cheapy seal open back side where you could see a spring that would provide tension on the rubber boot to create a seal. It did not work out so well, so I got a better one and it fixed it.
jasonty
41
Dec 23, 2018 01:00 PM
HookahRoo
Jul 20, 2015 07:06 PM
Iceman4193
Jul 15, 2015 04:48 PM
andrewtexas123
Jul 14, 2015 04:29 AM
jakebarrett
Jul 10, 2015 07:15 PM
