Truck acting up
Old Jun 7, 2009 | 12:53 AM
874runnersr5's Avatar
Truck acting up
Hoookay, so my 87 22re 5spd has been acting kinda weird the last two days.
Heres the problem, lower/slightly rough idle - wouldn't stall but if i gave it some gas it cleared up the higher rpm i brought it to. So i filled up with gas because i was on extremely low tank yesterday so i filled it up with some 90 octane to full. Still didnt help, its almost like a intermittent.
On the way home tonight, it drove fine for most part, its kinda on/off situation..
1st and 2nd lower rpm's feel gut less unless it put the peddle to the floor then it just feels like how it usually should be.
Any idea where to look? im thinking my tps again.. because i know i didnt get it adjusted spot on..
Recent things ive had done, new o2 sensor a year ago(10,000km's ago), new fuelfilter, new alt, new plugs/wires( no rotor/cap yet).
Thanks fellow yoties.
Old Jun 7, 2009 | 07:45 AM
yoterr's Avatar
well ide check off the easy stuff the TPS and the fuel filter (even tho its new) but running the truck low on gas pics up all the gunk at the bottom of the tank...and i think theres a little bag on the fuel pump that would get clogged first...
Old Jun 7, 2009 | 07:52 AM
hmm.....
Old Jun 7, 2009 | 07:57 AM
Kiroshu's Avatar
Maybe purge valve..... try tapping on the purge cansiter with a hammer a few times see if that help, purge valve may be sticking. PCV system fuctioning properly? Since you have not done distributor cap and button go ahead and try that its a cheap investment like maybe 8 bucks for em both.
Old Jun 7, 2009 | 08:06 AM
purge valve eh? should i tap it when its running or off?
il replace my pcv to and cap/rotor..
Old Jun 7, 2009 | 08:13 AM
Kiroshu's Avatar
i would not do it with it running first. try it with engine off, then start it and see, then tap it with engine on. this may not be a cure but its possible.
Old Jun 7, 2009 | 08:31 AM
Alright alright, any ideas what else it could be?
im kinda curious because its been running fine all week...
Old Jun 7, 2009 | 10:53 AM
K so i wacked it with my softface hammer not to much luck. it kinda stopped, so far its been good but sometimes it feels gutless.
Old Jun 7, 2009 | 07:24 PM
Woohoo, new cap/rotor and pvc valve bottle of mobile 1 grease and 12 bottles of castrol syntech diff/trans fluid about to go in.. hopefully she'll be happy and stop doing this haha.
Old Jun 9, 2009 | 10:44 AM
Kiroshu's Avatar
Well its possible EGR trouble if you have just about everything new. Try tapping on the EGR like the purge valve and see. Or if ya have the money its about time for a replacement EGR and OR!!!! You can try and clean out the passage in the intake manifold where the EGR bolts up too it.... it may be clogged. SEA FOAM.....?
Old Jun 9, 2009 | 02:11 PM
No erg, PO took it out. Looks like there is still some of the system in place il take some pics and post it up.
Lately its been good.. actually all day today she drove amazing.. so i have no idea.
Old Jun 9, 2009 | 03:06 PM
Hm werid, i can almost get my truck to backfire in 2nd gear 2krpm's going down a hill..
maybe she is running rich?
4x4-runner
Feb 26, 2017 06:42 AM
MadMax48
Jul 3, 2015 08:26 AM
serenity03k64
Jun 27, 2015 07:59 AM
Gadget
35
Jul 9, 2004 06:48 AM
