What is the best value about Idler Arm?
Old Jun 10, 2009 | 11:34 AM
fooboo's Avatar
What is better to get a new Ilder Arm or Rebuilt Idler Arm?
what is better? and tell me why?
ME: i was thinking about to buy a new one but i research about
it they said its better to rebuild and save money! but im not quite sure
about it. Give me a tips about it!
*need a new alignment*
after i need to finish the idler arm asap!
-22R
Old Jun 10, 2009 | 11:39 AM
4RunnerPete's Avatar
What kind of condition is the ball joint in? If that is shot, then there's no point in rebuilding the shaft. Autozone carries a duralast (i believe) part that is very similar to OEM, and I think it even has a bigger shaft diameter. Mine was $89, and its a relatively easy install. I would suggest just buying a new part. And do the arm before the alignment, or you'll have to do it again after anyhow.
Old Jun 10, 2009 | 11:48 AM
fooboo's Avatar
the joint is in bad condition...
it was loosing and my tire thread
was running out inside...
its better to buy a new part!
thanks!
Old Jun 10, 2009 | 06:19 PM
tc's Avatar
tc
How long has it lasted?
Personally, I did the bronze bushing rebuild and it has held up pretty well to some pretty tough wheeling with front/rear lockers...
Old Jun 10, 2009 | 07:39 PM
highonpottery's Avatar
try rebuilding it for under $10 and 1/2 hour of your time before spending ten times that much to replace it. that way you'll at least get a look at its guts and see if it is good to go or needs to go in the spare parts box.
Old Jun 10, 2009 | 11:07 PM
drew303's Avatar
new ones usually come with lifetime unlimited warranties. I'm gonna swap mine out for like i think my 5th one.. all free, then actually put a brace on it.
It's one down side to BJ spacers.
Old Jun 11, 2009 | 09:32 AM
dem0nk1d's Avatar
don't forget the autozone idle arm has life time warranty. =)
Old Jun 11, 2009 | 10:00 AM
Do the spacers increase the load on the actual idler arm, or are you breaking more because the lift exposed the arm more to rocks/etc?
ladybugRC
458
Aug 21, 2020 10:41 AM
ktm192k
Oct 1, 2015 08:47 AM
JookUpVandetti
Sep 30, 2015 08:58 AM
tylermx71
Sep 29, 2015 08:49 PM
crash813
Sep 27, 2015 07:15 AM
