'91 22RE starter removal
Old Jun 4, 2009 | 06:06 PM
Levis Pennae's Avatar
Yet another problem with removal of stuff. This time I need to replace the starter. The only problem is that the starter located in a void between the intake and EFI manifold and the front differential. I would rather not remove either one, any advice? I am replacing it with a rebuilt from Toyota.
Old Jun 4, 2009 | 06:12 PM
toyota4x4907's Avatar
the starter is pretty easy to replace. go through the passenger's side wheel well. Its RIGHT there. You should be able to access both bolts from there if you are a contortionist, but at least one. The other one you might have to go up from the bottom, but you do NOT need to remove any of that stuff.
Old Jun 4, 2009 | 06:15 PM
22repower's Avatar
On my 94 22re all that I had to take out was a small cover on the wheel well, and it seemed like no big deal.
Old Jun 4, 2009 | 06:17 PM
toy89yota's Avatar
lots of extensions
Old Jun 4, 2009 | 06:18 PM
Ok, thanks guys. I guess I've just been stupid.
Old Jun 4, 2009 | 06:19 PM
Just Learning's Avatar
thats what i did on my 92 took the wheel off and removed the small cover on the wheel well --cake
Old Jun 6, 2009 | 06:27 PM
I took Just Learning's advice, I was just a pain in the a$$ to get a wrench in there and even worst to get the torque bar in there.
Doug4320
Mar 24, 2018 10:11 PM
clok
Aug 1, 2015 09:42 PM
Hiluxtrucha
Jul 22, 2015 10:00 AM
ZONAYODA
Jul 13, 2015 07:17 PM
colinmil
Jul 6, 2015 04:03 PM
