will they fit alright?
Old Jun 8, 2009 | 06:21 PM
bwiygul's Avatar
just wondering because i'm looking at some wheels/tires a guys selling and i don't have a lot of time cause he's holding them for me but i have a 93 pick up and i'm going to put the ball joint spacers and the zuk spring mod on the back, will i be able to fit 33's in comfortably? thanks.
Old Jun 8, 2009 | 06:32 PM
bwiygul's Avatar
oh yeah, i'm looking at about 1.5/2" lift from stock. thanks.
Old Jun 8, 2009 | 07:25 PM
a4runnerfreak's Avatar
From: Grew up in S.C.V, So Cal.....now in Hampstead, NC
Fairly comfortably.....yes
Old Jun 8, 2009 | 07:35 PM
bwiygul's Avatar
thanks
Old Jun 8, 2009 | 07:40 PM
abecedarian's Avatar
like 'freak said, the tires will fit with the bj spacers. however, a good bump may cause the tires to rub since compression travel is limited by the lower control arm / bumpstop. bj spacers push the wheel down / frame up but don't do anything to limit the up-travel of the wheel any more than what stock wheels would experience.
Old Jun 8, 2009 | 08:07 PM
bwiygul's Avatar
cool...i appreciate it...i'm just getting some pretty nice american racing rims with 33" bfg mud terrains...guy needs to make rent so it's 250 for the set. i was planning on either running them till i need new ones or take em off and throw 31's on. not sure yet i'll see when i get em on. either way, it's mostly daily driver with the occasional off roader but mostly gravel and dirt. so hopefully they'll be alright...oh yeah, since i got you guys how bad will 33's hurt my power and mileage? will i need to re-gear the rear end? how about 31's? thanks.
Old Jun 8, 2009 | 08:16 PM
dropzone's Avatar
Fossilized
Originally Posted by bwiygul
will i need to re-gear the rear end?.
if your '93 is 4WD you will need to re gear the front end too
31's would not affect your truck nearly as much as 33's will impact your power/mileage...
Old Jun 8, 2009 | 09:43 PM
bwiygul's Avatar
so, one other tire question...the tires on the rims are 33x12.50x16.5.
do i have to get 16.5" tires? or will 16's work?
Old Jun 10, 2009 | 02:26 PM
dropzone's Avatar
Fossilized
if you have a 15" tire you need a 15" wide rim
if you have a 16" tire you need a 16" wide rim
if you have a 16.5" tire you need a 16.5" wide rim
16" tires say right on the side 'Don't mount on a 16.5" Rim'
Old Jun 10, 2009 | 02:31 PM
Lumpy's Avatar
33's should fit without the spacers but you have to watch the saggy butt as I found on the 4runner. I know yours are going on a pickup...
Check out this thread.
https://www.yotatech.com/forums/f116...-guide-155339/
Then...Oops
http://i714.photobucket.com/albums/w...py_91/Flx6.jpg
Didn't feel like posting the picture so I just gave the link. They fit fine in the front.
Corvoid
Dec 11, 2015 11:21 AM
chuckd83
Sep 14, 2015 03:20 PM
ac7822
Sep 12, 2015 06:57 PM
dbd6604
Sep 9, 2015 12:25 PM
anniesball
Sep 5, 2015 08:45 AM
