Help Diagnose my Tranny
Old Jul 16, 2008 | 07:15 PM
sleaz22xx's Avatar
Tranny tunnel around my A/T has been getting very hot as of recent, Today on the highway the A/T oil temp light finally came on. Pulled over let it cool, checked the fluid level and it was high. When i got to my destination i drained the pan (look burnt) and filled tranny to the appropriate level.
On the way home Tranny is still getting very hot and now i am getting a wierd noise on the highway when rpms drop to between 2500-2100(sounds like a vibrating grating noise). Also the tach drops dramatically to just under 2k
Other than the problem stated above, the tranny shifts nice and smooth.
Has anyone experienced similar symptoms or having any suggestions on how to save my tranny.
Is the tranny gone!?!?
Thanx in advance
Old Jul 16, 2008 | 07:31 PM
InternetRoadkill's Avatar
Sounds like a clutch is failing in it. Burned fluid is usually a bad sign.
Old Jul 16, 2008 | 08:12 PM
bigtrucknwheels's Avatar
torque converter is my guess.
I'll soon have an entire, perfect a340h for sale...
Old Jul 16, 2008 | 08:14 PM
JDMSLIK's Avatar
How many miles on the vehicle and how old is the radiator. Your ATF cooler sounds like it's plugging. I'd put an aftermarket cooler in first and see what happens.
Old Jul 17, 2008 | 03:20 AM
sleaz22xx's Avatar
around 110k on the truck , as far as i know its th original rad. What really concerns me is the vibrating grattig noise it make when rpms drop to around 2400-2100. any one one what this my be and if its salvagable?
Old Jul 17, 2008 | 05:04 AM
Actually, the torque converter has a clutch in it for locking up around those rpms in cruise. I think there's a way to disable the lockup, but I don't remember how. It may involve unplugging the electrics to the tranny. I'm not sure if the O/D switch disables the lockup or not.
Old Jul 17, 2008 | 05:50 AM
I was told the ECT button disables TCC lockup. but I am not positive on that one.
Old Jul 17, 2008 | 07:06 AM
If I'm understanding the FSM correctly, it looks like you can force the torque converter to unlock by applying the brakes enough to get the brake lights to come on. You can also keep the torque converter from locking up by placing the shifter in '2' which locks the tranny in 3rd gear with no lock-up.
If the noise goes away, it's time for a new torque converter. I feel for yah. I just changed mine.
Old Jul 17, 2008 | 04:50 PM
sleaz22xx's Avatar
I can only repeat the noise when the truck is over 50 mph, and between 2000-2300 rpm. Do you think "2" would be safe at these speeds?
Furthermore if I through it in "N" at around 50 , the noise will occur regardless of rpm. It sounds like a fast rattling coming from right below the tranny tunnel. Thanks for the help roadkill, ive been reading some of your post
Old Jul 17, 2008 | 05:51 PM
Should be safe to run 50 in '2'. That's 3rd gear. Just watch your tach if your worried.
Does the noise change pitch in 'N' when you rev the engine?
Old Jul 17, 2008 | 06:33 PM
sleaz22xx's Avatar
Doesnt change pitch but gets slower or faster with regard to RPM
Old Jul 17, 2008 | 07:38 PM
Well that's what I meant. (Bad word choice on "pitch".) I think your torque converter has moved up to prime suspect status. No fun to change, but it's better than rebuilding a tranny.
You should flush and drain the fluid as well as change the filters (There's two: one in the tranny and another in the transfer case) when the torque converter gets replaced. If the converter is shedding metal, you want the dirty fluid out of there.
ladybugRC
458
Aug 21, 2020 10:41 AM
TheBFA
Feb 15, 2020 06:55 AM
live4soccer7
May 11, 2016 06:52 PM
smilen724
13
Nov 8, 2015 04:11 PM
Davebarbier
Nov 3, 2015 03:28 PM
