average cost of headgasket replacement??
Old Jul 21, 2008 | 09:42 PM
Marc P's Avatar
After 6 years of hard driving my headgasket gave up on Saturday. I had some cooling system issues about a month ago, but replaced the radiator, all of the hoses, and installed another Taurus fan.
After a brief stop the engine started running really rough, so I limped the last mile home. Once I stopped I noticed coolant coming from the exhaust flange right before the cat...luckily there is no coolant in the oil.
I know there are a ton of HG stories on this board.....what have you paid to have it done? And what did it include?
Old Jul 21, 2008 | 09:54 PM
georgiayota's Avatar
i am in the middle of replacing the head gasket on my truck right now... (22r)
stuff that i got
Head shaved= $40
head gasket= $25
intake gasket= $4
exhast gasket= $17
valve cover gasket= $13
timing set= $90
timing cover gasket= $7
water pump= $22
Old Jul 21, 2008 | 09:55 PM
Marc P's Avatar
Sorry...looking for 3.0 info
Old Jul 21, 2008 | 09:57 PM
well cant help ya on that, i am sure there is someone else here who can
Old Jul 21, 2008 | 10:00 PM
camo31_10.50's Avatar
idk if they sell them..but i would recomend ATTARCO heads..and do it yourself..its ALOT cheaper..our head for our 22R was less than $250 shipped to our door..and everything was there..all was and still is well..
Old Jul 21, 2008 | 10:09 PM
anotherjeff's Avatar
Has your 4Rnr had the "recall" (freebie) HG job performed yet?
Old Jul 21, 2008 | 11:24 PM
EWAYota's Avatar
Not sure what it would cost for the 3.0, but this is what I did to save on some labor on my 22RE.
I went ahead and tore it down, labeled everything, bagged everything. I did as much prep work to everything as I could, ordered all the parts I wanted and then when it was ready to get buttoned up, I towed it down to the mechanic.
Took it down in the morning, had it back in the evening. 350.00 plus what I ordered.
Old Jul 22, 2008 | 09:13 AM
Blurr's Avatar
technically you could do the HG job on the 3.0 for the price of the gaskets alone ($100 or so) but that wouldn't be the wisest move. while the top end and front of the motor is all torn apart, it is HIGHLY recommended to:
-deck and pressure test the heads
-do a valve job
-replace head bolts
-clean/test the fuel injectors
-replace ALL coolant and vacuum hoses
-replace timing belt/pulleys/tensioner/water pump/thermostat if they haven't been done in the past 12k miles
-all timing components if they haven't been done in the past 6k miles
I guess it all depends on what your intent is with your vehicle. if you want to keep it, definitely do all of the work listed above. you'll be spending about $750 +/-, more if you need to buy additional tools.
Old Jul 22, 2008 | 09:21 AM
Tacoclimber's Avatar
Bummer to hear about this Marc...
The only HG experience I have with with a 22R, so that's no help.
How about swapping in a 3.4?
Old Jul 22, 2008 | 05:19 PM
Mr_Martinez1982's Avatar
some what of a thread hijack
Valve Job, pressure test, resurface, Valve job/ adjustment-
618.80
Knock sensor- 11.00
Timing belt tensioner spring- 8.00
Head Set- 188.99
Timing belt 27.89
Timing components 98.99
Waterpump- 46.79
Headbolt set (for both) 62.98
i consider the above necessary- total $1100
Now, dont laugh....
Powersteering pump 109.95
DT headers 674.40
Jardine cat back 264.37
Flex-a-lite (ebay) -/+ 60
Pc board and thermo for fan 60
New total 2232.16
i knew there was a reason i had not added up all the reciepts, it runs great, definite power gain, sounds good too, but the GPM are still about 17-18 on highway if I drive it conservatively. which doesnt happen often. but the way i saw it, w/ the headers i eliminate any future HG issues (with proper maintenance ofcourse).
Now, ive come across a possible 91 4runner. for obvious reason i will not be going this route again... TacoClimber suggested a 3.4 swap, can any of the people that have done a swap, make some kind of list, sort of like mine? or point me in the right direction? ive tried reading a few of the swap threads but.....
Old Jul 22, 2008 | 08:06 PM
Marc P's Avatar
The 2 choices I have come up with are---
having a Toy master tech replace headgaskets and have heads resurfaced for $1400 parts and labor. I had the timing belt, thermostat, and water pump done about 25k ago.
Or I am looking at this reman engine...
http://www.toyotatruckpart.com/defau...FSgtagodXn0wkQ
Anyone use this company??
Old Jul 22, 2008 | 09:24 PM
Swansen's Avatar
http://www.rockauto.com/catalog/raframecatalog.php
Rock auto offers Long blocks, and they use Marshall engines, and they do good work, and Rock Auto are good people. On that, if you are considering a new engine, look into some JDM engines, i'm sure there are everywhere. On that, the 3vze's are everywhere, and for cheap to.
Eggslinger
Jun 8, 2019 03:32 PM
Sep 4, 2015 09:27 AM
akaphilly
Jul 9, 2015 02:18 PM
Nickdigg
Jul 7, 2015 06:04 AM
Vargntucson
Jul 4, 2015 12:15 PM
