what causes this whine?
Old Jul 20, 2008 | 11:53 AM
CenCalRunner's Avatar
I'm getting a low pitch groan/whine when I turn the wheel (and yes the ps fluid is full) Most noticeable during slow speed parking maneuvers when the steering is strained and the wheels trying to turn. If the truck is stationary and I put some pressure on the steering wheel, but not enough to turn the wheels, the noise pops up. Any thoughts? Thanks.
Old Jul 20, 2008 | 12:02 PM
dirtoyboy's Avatar
A lot of toyotas have the power steering "whine" you mention...
How loud is it? Could just be a pump going out...I wouldnt worry about it unless it gets bad
Old Jul 20, 2008 | 12:48 PM
apalmer1's Avatar
yeah its just the power steering pump expressing its exasperation. just keep using it till it dies and then replace it, some of those things will whine like a banshee but still wont die for years and years.
Old Jul 20, 2008 | 12:51 PM
abecedarian's Avatar
yep- power steering pump.
If it's annoying you, try draining and replacing the fluid.
Old Jul 20, 2008 | 01:23 PM
thook's Avatar
Yep....sometimes you have to replace the fluid, actually. It does wear out. Flush the system.....see if that helps.
(Abe....what the hell happened to interesting sig?)
Old Jul 20, 2008 | 01:26 PM
thook- found out I work the most deadliest job in america so I'm re-evaluating my sig...
Old Jul 20, 2008 | 01:33 PM
Jay351's Avatar
Drain and fill with Dextron lll AFT fluid. My old pump used to whine.. alot. It got bad and the pump pulley walked out and almost went into my rad...
Keep an eye on it, if it gets worse. Look for a used pump. Good ones can be had for under 50 bucks.
Old Jul 20, 2008 | 01:35 PM
yeah, I guess someone should point out that groaning and whining from the steering pump means that the pump is vibrating.
Old Jul 20, 2008 | 05:04 PM
Thanks for all the input. Its pretty annoying so I will try replacing the fluid and keep using it until it either quits completly or I go insane driving my truck.
Old Jul 21, 2008 | 08:13 AM
anyone know how much atf I will need to re-fill the ps system? I see 400cc in the fsm, is that correct?
Old Jul 21, 2008 | 08:16 AM
dirtoyboy's Avatar
cant remember the quantity...its a few quarts though....I usually use Valvoline MaxLife
It could also be a leak somewhere in your system letting air into it.....double check that...air in the system can make it whine pretty bad...
Draining and refilling the system is really easy...shouldnt take more than ½-1 hour to do
I8URSVT
Jan 15, 2016 07:25 PM
Higbee89
Aug 27, 2015 06:52 AM
norcal98
Aug 10, 2015 06:20 AM
Jonny246
Jul 24, 2015 12:37 PM
mengquis
Jul 13, 2015 10:39 AM
