2wd and 4x4 rear leaf interchangeable?
Old Jul 12, 2008 | 12:07 PM
str8_6's Avatar
i cant find this information anywhere. from all the wheel hop i found out that my rear leaf springs are actually starting to bend upwards...not downwards.
so i went to the junk yard and they gave me leaf springs for a 4x4 94 extended cab. i have a 93 2wd standard cab.
i measured the 2wd at 51" eye to eye(keep in mind the spring is bent to S***)..so i think its longer then normal.
the 4x4 rear was like 48".
it looks doable i just want some confirmation. if they work i'll just put lowering blocks on those to even it out and it wont sit so high. thank you!
Old Jul 12, 2008 | 12:12 PM
4Crawler's Avatar
The 4WD springs should also be 51" long if they are from an '89 or newer pickup:
- http://www.4x4spot.com/misc__spring_information.htm
Did you measure along the arc of the spring or from eye to eye? Proper way is to lay a tape along the arc of the spring.
Old Jul 12, 2008 | 04:37 PM
str8_6's Avatar
ah thats where i went wrong. the 2wd springs are flatten out and i measured eye to eye where the 4x4 springs were still proper and i measured eye to eye. thanks.
smthwsn357
May 1, 2024 07:28 AM
Colington
Mar 8, 2020 09:51 AM
mskalmus
May 28, 2017 07:51 AM
icentropy
Jul 9, 2015 02:12 PM
Nickdigg
Jul 7, 2015 06:04 AM
