Project OD
Old Jul 14, 2008 | 02:27 PM
HAVOC's Avatar
Project OD
Why OD? Because that's the color it will get painted (olive drab).
1995 Toyota ext. cab 3.0V6 5-speed 4X4
I bought this truck to replace my current DD. It had a rod knock and for $500.00 it was a good deal.
Pulled the engine out and waited on a crank.
In the mean time I'll install the 2" body lift.
When I got the bed off I noticed some surface rust.
Then the wheels started spinning.
I bought this for $150.00 (not the floor jack )
Out came the torch.
Now the truck is just a cab and frame. I scrapped the bed because it was dented and rusted pretty bad. I also scrapped the parts I wasn't going to use and made back $250.00.
The plans are to rebuild the 3.0 (maybe a 3.4 swap), 5" SAS, 5" rear lift, 2" body lift, rear brake disc swap, transfer case e-brake, and some other little things to make it my own. This will be a slow build so don't expect too many updates at first. I would like it running by winter, but you know how these things go. I'm changing the gears in my DD and welding the frame (rust) so that will have to come first. So stay tuned, there may be some useful tech you can use, or cure your insomnia.
Either way, it will be helpful.
Old Jul 14, 2008 | 10:35 PM
just a 22re's Avatar
nice buy man and good picks on the work your doing to her but 5in plus 2in that alot of lift just becarefull with her she might get a lil top heavy
Old Jul 14, 2008 | 10:42 PM
traben27's Avatar
x2 on the top heavy. why so much lift?
Old Jul 14, 2008 | 11:53 PM
Matt16's Avatar
Why the lift? The top heaviness will limit the capability more than the flex will help.
Old Jul 15, 2008 | 02:54 AM
HAVOC's Avatar
I'm going to install 35's when I'm done and I dont want to do any trimming. Won't the springs settle a little, say 1 or 2 inches?
Old Jul 15, 2008 | 03:56 AM
SwampThing's Avatar
Depends. Who're you getting your springs from? I have 5" trailgear springs, and the front (got the heavy duty springs) settled about a 1/2", and the rears settled about 2"
Old Jul 15, 2008 | 08:22 AM
HAVOC's Avatar
I'm getting the front and rear kits from marlincrawler.com.
Old Jul 15, 2008 | 08:32 AM
dirtoyboy's Avatar
You can run 35's with 3 or 4 inch springs MAX (NO body lift) no trimming required...7 inches is HUGE
EDIT: I have 36" tires ....exact same truck with marlin 4 inch US springs NO body lift and its perfect
83yotastockR
11
Nov 10, 2015 06:54 AM
tylermx71
Sep 29, 2015 08:49 PM
Toys4parts
Sep 26, 2015 01:56 PM
toyotasaurus
Sep 24, 2015 03:30 PM
justdifferentials
Sep 5, 2015 06:52 PM
