Clutch Sounds
Old Jul 12, 2008 | 08:56 PM
g_mau18's Avatar
Clutch Sounds
Hey I just installed a new clutch and whenever I rev up and shift you can hear the fingers of the clutch spinning or something like that. Has anyone had this happen? Or is it because its still new? Maybe I installed it wrong.
Old Jul 12, 2008 | 09:32 PM
thook's Avatar
No. I've only heard the feet....from the hole in my floorboard...Fred Flintsone style.
Seriousl, though....I'm really not sure what you mean. Could you be a bit more desciptive of the sound? Any problem shifting or maintaining gear?
Old Jul 12, 2008 | 09:40 PM
abecedarian's Avatar
Might you be hearing noise from the clutch release bearing (a.k.a. throw-out bearing)? The "fingers" on the pressure plate contact the bearing as does the release lever (fork). If the bearing is worn, you might get some noise from it when you apply the clutch.
Old Jul 12, 2008 | 10:03 PM
g_mau18's Avatar
No, no problems whatsoever with shifting or maintaining gear, just a irritating noise, kinda hard to describe but a spinning sound, definetly the "fingers" of the pressure plate, just sucks because its totally new.
Old Jul 12, 2008 | 10:10 PM
I'm almost willing to bet that the new clutch is more quiet than the old one and now you're hearing noises that were there all along, but were hidden, so now you are thinking it's the new clutch making the noises.
Old Jul 13, 2008 | 02:28 PM
GLT-4-6's Avatar
Did you replace the throw out bearing and pilot bearing with the clutch and pressure plate? That is probably the noise you are hearing.
Old Jul 13, 2008 | 03:13 PM
Jay351's Avatar
You sure you got the correct clutch?
Old Jul 13, 2008 | 08:22 PM
GLT-4-6's Avatar
I didn't think about that. The first time I replaced my clutch I went to Vatozone and the one they gave me wasn't right. The teeth or "fingers" on the pressure plate were longer than the stock ones. I pickup a clutch from Advance auto parts and it matched up perfect. This may be the case here.
he's gone
7
Dec 3, 2019 07:08 AM
akamon808
3.4 Swaps
Dec 16, 2015 08:45 PM
norcal98
Aug 10, 2015 06:20 AM
PlayAwhile
Jul 20, 2015 11:36 AM
1996Taco
Jul 20, 2015 12:02 AM
