A few questions about AC, Stereo and Spedo
Old Jul 22, 2008 | 02:08 AM
Myron's Avatar
ac- So i noticed yesterday that when i turn on my AC, my idle drops and can hear the ac kick on, but i feel no air blowing..then i move the dial up to II and higher and then i feel some air. Is it something electrical (dirty switch_?
Stereo- I cant connect my amp because all i get is engine noise. I am using 4 gauge wiring and grounding it between the truck and the seatbelt bolt. any ideas...I disconnected the amp, and im still getting engine noise w/out the amp.
I am using good quality RCA's and a pioneer deck (new model)
SUB Measurement. I searched through the site and saw a few post that people showed their sub set up but could not find any measurements.
Im trying to at least get a 10" behind the seat. Been a king cab..its freaking hard. any ideas?
Spedo- is it possible to put a spedo with rev counter in my 87 truck.
Thanks for the help
Old Jul 22, 2008 | 02:18 AM
Elton's Avatar
for the stereo run ur rca's away from the power wire sand down the area around the ground wire also running a few new grounds wires one to the frame one to the engine somewhere and one to the body may help
Old Jul 22, 2008 | 12:46 PM
just a 22re's Avatar
ok yeah this is what you do
take the end of your rca's at the back of the radio and strip on side dont mater what one if you wanna do both them do both now take the out side of the rca the bare wire (dont mess with the inside dont need to) and wrap a wire around it tape it off take tat wire and ground it now you should not have any more engine nose right if you do then call me man ill walk you though it step by step and answer any questions about car audio i used to do it for a living for many many years im 23 ive done it for 10 years!
as for the box ha ha i go0t two trens to hit a 150db(mtx 4000 w/500 watts) behind the seat of a reg s-10 yreah thats goes seat back wall you just have to move the seat up about 4 inches and biuld it to fit!
for the ac does it do it whit the heater on to or just on ac?
speedo with a rev counter? i dont get it you wanna add a sr5 cluster to your rig so you have the tach? yes you can it just a plug AND PLAY
YOU MUST REPLACE THE OIL SENDER TO A OIL PRESSURE SENDER FROM A SR5!
Old Jul 22, 2008 | 12:54 PM
4Crawler's Avatar
For the A/C idle issue, turn up the A/C idle up adjustment knob:
http://www.4crawler.com/4x4/CheapTri...ine_Pix/7.html
Old Jul 23, 2008 | 09:16 PM
X-Tool Pimp's Avatar
MOD EDIT: (By Lysmachia) BANNED and you know WHY!
Last edited by Lysmachia; Jul 23, 2008 at 09:17 PM. Reason: Banned for breaking OBVIOUS rules!
Old Jul 23, 2008 | 09:22 PM
DeathCougar's Avatar
Poor molly...has to clean all that up
Old Jul 23, 2008 | 09:23 PM
thank you my dearest mod!
Old Jul 23, 2008 | 09:24 PM
iamsuperbleeder's Avatar
good job on the ban... friggin spammers... nothing better to do huh... that's sorry...
how does one qualify for a mod or apply? think I may look into that...
Old Jul 24, 2008 | 12:34 AM
Myron's Avatar
Who got banned....ME?
im confused...did i miss something?
Old Jul 24, 2008 | 04:39 AM
happened around 2am last night (here time anyway), but it's over now... a spammer from another forum flaming...
Old Jul 24, 2008 | 09:03 AM
CRamsey's Avatar
On the AC fan speed issue, there's a resistor type thingy on the fan motor housing that controls the fan speed. It's located at the base of the housing, near where the motor brushes are. It has different sized coils on it that will burn out after time. I kept losing high fan speeds till it just quit. Finally figured it out and replaced it at the stealership: $15.00.
Old Jul 24, 2008 | 11:20 AM
Myron's Avatar
Ill check that out...thanks for the info
r3dfish
54
May 16, 2016 10:31 PM
theking11863
Mar 19, 2016 09:36 PM
skoob
Oct 15, 2015 03:23 PM
corey519
Aug 12, 2015 11:12 AM
Esibnitsud
Jul 30, 2015 08:19 PM
