Weird Noises when turning
Old Jul 12, 2008 | 06:10 PM
g_mau18's Avatar
Hi this is my first post, this sites awesome. I run a '88 yota pickup and whenever Im turning left or right theres rattling coming from the front and when I make sharp lefts or rights at slow speeds theres a horrible popping noise, Has anyone had this problem before? What kind of expense am i looking at? Thanks.
Old Jul 12, 2008 | 06:14 PM
Corey's Avatar
Co-Founder/Administrator
Pop pop fizz fizz, that would be your steering stops in the IFS.
https://www.yotatech.com/forums/f116...appens-149198/
Old Jul 12, 2008 | 06:17 PM
Myers504's Avatar
yeah i think it will be the power steering if i am correct.
my truck does it to and its a 88 4runner
so i think its normal
-myers504
Old Jul 12, 2008 | 06:21 PM
g_mau18's Avatar
My truck doesnt have power steering though.
Old Jul 12, 2008 | 06:23 PM
Myers504's Avatar
well its making a poping sound.ummmm
my truck does that to when its not warmed up tho.
do you mud bogg alot?
Old Jul 12, 2008 | 06:25 PM
g_mau18's Avatar
Not a lot but I do take it to the trails everyonce in a while.
Old Jul 12, 2008 | 06:31 PM
Myers504's Avatar
you might have mud or sand caked in the rotors.and in the tirods.
thats a maybe
-myers504
abecedarian's Avatar
have you checked the disc brake shields or maybe the grill or lower valance for the cause of the rattle?
... and the clicking or popping may be the steering stops or if your hubs are locked the outer cv... or ball joints if they're really dry
Old Jul 12, 2008 | 06:40 PM
EWAYota's Avatar
Cough, cough, 2nd post, cough, cough
Old Jul 12, 2008 | 06:43 PM
lol
first post:
Old Jul 12, 2008 | 06:45 PM
EWAYota's Avatar
Originally Posted by abecedarian
lol
first post:
I read that, mine does that too when they need regreasing.
Old Jul 12, 2008 | 06:52 PM
rattles too huh? I wouldn't've thunked it.
*filed away in the cerebellum*
Old Jul 12, 2008 | 06:53 PM
EWAYota's Avatar
And just for extra info, when your hearing the rattling noise when turning, is that on a smooth road or bumpy, like turning over a speed bump or anything?
Might want to check out your cv boots as well to see if their torn. That can give you a rattle noise or slight popping noise when turning.
Old Jul 12, 2008 | 06:56 PM
Fink's Avatar
The popping sound is the steering stops for sure. As far as the rattles go I would do a search and see what you can dig up.
The Search feature is the most valauble feature of this board - and most other forums too for that matter.
There is a lot of info on this board, in order to find 99.5% of it you will need to search.
Fink
Old Jul 12, 2008 | 06:59 PM
EWAYota's Avatar
After second thought and a Sobe, I might get the rattle at almost full lock, but not far enough to make it grind, if that makes sense.
Thats where my cv idea comes into play. Had a 87 New Yorker with a torn boot that popped/rattled on every right hand turn and worse when hitting a bump or pot hole.
Old Jul 12, 2008 | 07:44 PM
being a former 84 chrysler laser owner (which shared the chassis with the new yorker / le baron), I know about cv sounds... however the noises I heard from bumps was usually the POS upper strut mount.
Old Jul 12, 2008 | 08:55 PM
thook's Avatar
The idler could be a culprit, too.
ripp96
Jul 25, 2015 02:32 PM
yourrealdad
Jul 21, 2015 11:13 AM
icentropy
Jul 14, 2015 10:23 AM
jon.r
Jul 11, 2015 03:34 PM
smiley52
Jul 11, 2015 05:16 AM
