Need diagnosing help
Old Jul 16, 2008 | 05:45 AM
Gavy's Avatar
So a week ago I start smelling gas then I have trouble starting my pickup it will turn over but will not start it just sits and turns over like 15-20 times then starts so after looking around I notice a slight gas leak I take it into my mechanic and low and behold I need a new sending unit putting 2 and 2 together I figure the trouble starting was the low pressure in fuel due to the leak so after dishing out $200 ish odd dollars for a sending unit I get it back and to my surprise it is still having the starting trouble my battery is an eveready and the label says January 06 I checked my plugs and plug wires and all seems good and tight my belts are tight as well so my question is this what could be causing this Starter? battery? Alternator?? I would ahve guessed battery but I would assume that it would ahve trouble turning over which it doesn't it just has trouble starting after turning over like 20 times
Old Jul 16, 2008 | 06:23 AM
Crawdad's Avatar
Cold start injector either gone out or leaking?
Old Jul 16, 2008 | 06:26 AM
Team420's Avatar
X2 on the csi....are you still smelling gas?
Old Jul 16, 2008 | 06:42 AM
blueyoda's Avatar
I was told by the yota mechanic at the stealership that the csi dosn't even come into play until sub zero temps? This is when he told me to replace the relay behind the glove box. It solved my problem, but mine would not start period (sometimes) and other times fire right up. I could always bump start it so he narrowed it down to the relay. A few years ago I had a leaky injector on #5, this was causing leghtly starts, I changed that one injector and it started fine.
Old Jul 16, 2008 | 06:47 AM
Team420's Avatar
Unless it is stuck open...
Old Jul 16, 2008 | 06:49 AM
Gavy's Avatar
So your saying I should try changing my relay and then if that doesn't work maybe see about the injectors and no I am not smelling gas anymore
Old Jul 16, 2008 | 06:58 AM
blueyoda's Avatar
If there is no gas smell than it is not likely an injector. When my realy was bad my truck WOULD NOT START. I had to bump start it, or turn the key of and on 20-30 times for it to engage. If you are only turning the key once than I don't think it is the relay. Even thought the battery may seem fine, try boosting your truck with another vehicle that is running. If it starts right away, the battery has enough power to crank, but mabye not give a good spark.
Old Jul 16, 2008 | 07:01 AM
blueyoda's Avatar
I also see your truck has very low milage. Congrats but trucks that have sat for extended periods of time often aquire wierd problems. Not sure if this is the case. Does it run fine after starting? does it start right away after it takes a long time the first time?
Old Jul 16, 2008 | 07:04 AM
Gavy's Avatar
Ok I'll try that as some of you might know by my other posts this truck has 58K original on it right now and its a 94 I believe that whoever had it before me let it sit for a good while when I got it the oil was like jet black from not being changed the timing chain was already on its way out and now I had the sedning unit and the lenthy starts I think I'm seeing def proof that letting a vehicle sit is bad bad bad
Old Jul 16, 2008 | 07:06 AM
Team420's Avatar
isnt there a check valve somewhere in the system that keeps fuel from leaking back into the tank? maybe try turning the key to the on position without starting a couple times then, try turning it over...you may just need to "prime" the system....dunno, tho...I'm just guessing.
Old Jul 16, 2008 | 07:14 AM
Gavy's Avatar
Yeah I'm not sure maybe i'll try that as well
Old Jul 20, 2008 | 03:39 PM
84sr5yoty's Avatar
It comes into play below 80F
Old Jul 20, 2008 | 07:13 PM
blueyoda's Avatar
Below 80f? that counts as cold, I guess it refers to engine cold not ambient cold.
Old Jul 21, 2008 | 10:48 AM
Gavy's Avatar
So I messed around alil this weekend and I tried jumping the truck with my fiances xterra while it was running and the condition did not change i then tried just turning the key to on for a few seconds and then starting and still the condition remained unchanged its wierd because once I get it started it runs fine idles good shifts good and accelerates good I have no other symptoms other than the damn thing just keeps cranking 20-30 times before it starts
Old Jul 21, 2008 | 11:50 AM
Flash319's Avatar
Could also be the AFM (air flow meter). If it is stuck and not seeing air movement you will not get fuel. Try holding the flap open abit with your finger.
shisha1999
Mar 3, 2016 07:09 PM
smilen724
13
Nov 8, 2015 04:11 PM
shredder4286
Oct 1, 2015 01:09 PM
bradahman
Oct 1, 2015 09:24 AM
