I need some advice 22r alternator problem
Old Jul 21, 2008 | 07:35 PM
87yoda87's Avatar
I just switched out a 1983 22r into my 1987 4x4. I removed the stock 87 22r. I got everything hooked up the truck will start and run, but the alternator is not charging the battery.(Alternator is brand new) I had to cut the plug that goes to the alternator from the chassis, and I tried splicing the wires but if I unhook the battery the truck dies! I have the main wire coming off the alternator bolt, and then 3 small wires. I have tried splicing them almost every possible way but truck still dies when I take the battery off. I have tried to look at the book, but it seems like I did everything right, is there something else to check? The fuses all looked good.
Old Jul 21, 2008 | 07:39 PM
abecedarian's Avatar
should've kept the 87 alternator and wiring.
Old Jul 21, 2008 | 07:40 PM
engine swaps should be only long block swaps. everything bolted to the original engine should be carried over to the new engine.
Old Jul 22, 2008 | 01:25 PM
87yoda87's Avatar
is there anyway to get around this without installing the 87 alternator and bracket?
Old Jul 22, 2008 | 08:49 PM
DeathCougar's Avatar
No. The 83 is externally regulated, the 87 is internally regulated.
Use the 87 parts.
Old Jul 22, 2008 | 09:30 PM
Swansen's Avatar
just curious, but why are you against the 87 alternator ??
Old Jul 22, 2008 | 11:03 PM
gsb15's Avatar
deathcouger is right, the 87 alternator has the voltage regulator attached, where as in an 83 its on the drivers side inner fender. the alternator should always match the harness, even the early ones that we externally regulated are wired differnt in differnt years
Old Jul 23, 2008 | 02:39 AM
Robrt32's Avatar
AC Delco 1 wire unit........easy and cheap fix
Old Jul 23, 2008 | 05:51 PM
87yoda87's Avatar
would that be like a chevy alternator? Does the 1 wire just go to the battery and thats all the wires you have to worry about? What about it fitting the mounting brackets? I have an 87 alternator, but I think I will have to pull the motor back out to get the brackets for the 87 on.
Old Jul 23, 2008 | 05:54 PM
search the fora here. I wrote up a bit about wiring the alternator and which wire goes where. Not exactly a 1 wire install, but all the details.
saved you the probs-
https://www.yotatech.com/forums/f116.../#post50851269
using the 87 alt.
Old Jul 23, 2008 | 06:22 PM
87yoda87's Avatar
well the brackets look to hard to take off and to put back on without pulling the engine out. I think I will try to use the 87 alt and just build a new bracket using the 83 stock brackets.
Old Jul 23, 2008 | 06:25 PM
Too hard?
You swapped an engine, but 4 bolts is too harD?!
Old Jul 23, 2008 | 07:22 PM
Swansen's Avatar
Do you mean hard, as in they might stripe or are rusted on?? or do you actually mean they look like they are to hard to get off because of where they are?? Ether way, its probably not actually that bad. Actually, i think they are the same brackets on the 22RE, and i've had those off, they are not that bad.
Originally Posted by DeathCougar
Too hard?
Old Jul 23, 2008 | 08:48 PM
87yoda87's Avatar
no they look like they are hard to get to, and I think you have to take several other things off to get the bracket off.I dont have the truck here with me, I am trying to remember though.
Old Jul 23, 2008 | 08:58 PM
X-Tool Pimp's Avatar
MOD EDIT: (Lysmachia) BANNED!
X-TOOL posted 60 bannable images. Way tooo much crap.... I coulda banned all posts but I wanted everyone to see what a jerk he was. 60 posts of the same Image... I hand cleaned this one.
Come on Guys! We ALL OWN YOTA's Who cares? Let's leave the fighting to the hummer guys!
Old Jul 24, 2008 | 02:40 PM
87yoda87's Avatar
What is all that about????????
Old Jul 24, 2008 | 03:19 PM
he posted many pictures of a middle finger with "F" yotatech in the middle of it. Posted in any thread he could get in. Big dramafest last night brought to you by the Rock Winers 4x4 club.
Old Jul 25, 2008 | 06:03 PM
87yoda87's Avatar
what does people do to install the 1 wire chevy alternator? Do you have to fab your own brackets?
Old Aug 12, 2008 | 05:42 PM
87yoda87's Avatar
OK, I finally got around and installed the 87 alternator and mounting brackets and returned the truck back to stock on that part of it. I respliced the wires back to the original plug for the 87 alternator. I started the truck and removed the battery cable and the truck dies. The alternator seemed to work when I bought the truck but not 100% sure. Also, the 87 alternator has been setting out in the weather for about 2 months and has been rained on and wet. Do you think the alternator is just bad or.....? All the fuses in the black fuse box are good. Any other ideas?
Old Aug 13, 2008 | 01:51 PM
87yoda87's Avatar
I bought a brand new alternator today and put it on the truck. I started the truck up, and let it run for a minute. The charge light on the dash wont go off, and when the truck is running and I pull the positive cable off the battery the truck dies. What else could it be?
