94 DLX 4WD wierd speedometer!!!
Old Jun 26, 2020 | 02:28 PM
gkaudio's Avatar
1994 Pickup DLX 3.0 Auto Trans. 4WD.
New speed sensor installed first. Odometer works fine. Speedometer doesn't register, but after driving a short distance it will start working.
Weird part is when I use a turn signal, it will jump to zero on the first blink, then return to normal speed. It's fine until I use the other signal,
and it does the same thing. Bad ground? Help, I'm confused.
Only other issue is that I just filled it up but the fuel gauge won't go past 1/4 tank.
Old Jun 26, 2020 | 02:44 PM
irab88's Avatar
The turn-signal-jump thing happened to me. It turned out to be a bad flasher relay. Get an electronic flasher relay, should go away.
As for the fuel gauge, probably a bad sender unit. There's an article I saw (maybe on here?) that showed how to fix it.
SurlyJohn
Aug 20, 2021 07:49 PM
whiskey79
Aug 2, 2019 10:12 AM
gamerndm
Aug 2, 2019 10:08 AM
InsigZi
Aug 1, 2018 02:08 PM
travisamorgan
Mar 8, 2015 02:19 PM
