I'm looking to replace my injector connectors (nice ring to that) on my 89 yota pickup 3.0l v6 3vze. Wondering if these would work https://www.ebay.com/i/152044755783?chn=ps attached is a pick of current connector
When you buy these connectors, you need a decent photo of the working end. I can't tell you the application, but there exist this type of connector with the tabs on the "other side" of the connector.
The set you cited to have the pre-installed "pigtails." Probably okay for doing just one, but if you do the whole set of 6 you'll have a mess of 12 in-line joints to deal with. You'll do much better getting the connector bodies and the pins. (e.g., https://www.ebay.com/itm/6x-Nippon-D...g/283032026856 ) Use a small screwdriver to open the insulation crimps on your existing wires, then cut off the part crimped to the wire (I found it just too difficult to open the crimp on the wire). This only shortens the wire by about 2mm, so you'll have plenty of slack. You'll need a crimping tool that "curls" the crimp together, like this: https://www.ebay.com/itm/Powerful-SN...S/173572556675 Don't try using regular pliers; you'll get a bad crimp.
