Brake Lights
Old Jan 25, 2015 | 07:09 AM
Unsurpassed's Avatar
Brake Lights
I'm new to this sight and also owning a Toyota. I bought a 1992 Toyota Tacoma Sr5 3.0 V6 4WD automatic. Original motor. Truck has 133,000 miles. My concern is my break lights don't work. Fuse is fine. Headlights also don't work on bright. Would greatly appreciate any advice. Thanks
Old Jan 25, 2015 | 07:25 AM
bswarm's Avatar
Check the brake light switch, it's on the brake pedal linkage & has two wires going into it. High beams could be the headlamp switch or relay.
Old Jan 25, 2015 | 09:02 AM
Ok. I'll try that. Thanks a ton.
Old Jan 25, 2015 | 11:24 AM
wyoming9's Avatar
Red face
Curious to see a 1992 Tacoma??
Old Jan 26, 2015 | 07:31 PM
RAD4Runner's Avatar
You could start by finding a schematic of your truck and posting it so others can help. I have a first-gen 4Runner, but can if I'm looking at schematic for 1992 truck.
Then, Got multi-meter?
How do you know that fuse is fine?
Both High Beams do not work?
Does flash work? If it does, it's most likely the high beam contacts on your dimer-combo switch (stalk).
Again, Got multi-meter?
Old Jan 26, 2015 | 07:56 PM
rworegon's Avatar
The Tacoma first came out as a 95.5 model year and never with the 3.0 V6 as the original engine.
So....not likely you have a 92 Tacoma as least here in the USA.
ashersullivan88yota
Jan 18, 2022 05:37 PM
fountain
Dec 31, 2015 06:08 AM
Sep 4, 2015 09:27 AM
Sandman
Jul 14, 2015 12:36 PM
Johntom240
7
Jul 13, 2015 12:18 AM
