Transmission question
Old Jan 16, 2015 | 09:10 PM
Corey Barlow's Avatar
92 4Runner 3.0 4x4 auto trans. Today I went to drive and put the trans in reverse and the motor revved like it was it neutral so I put it in drive and the same thing happened, so I put it back into reverse and revved it little more and it finally catches and drives fine for the rest of the drive. What could cause this?
Old Jan 16, 2015 | 09:42 PM
Xinorok's Avatar
First step would be to check fluid level and condition.
Old Jan 16, 2015 | 10:24 PM
Yea I didn't have time tonight but I'll start there in the morning
Old Jan 16, 2015 | 11:32 PM
Xinorok's Avatar
If that checks out, then next maybe look at the shift linkage. After that, you're probably looking at solenoids, etc...
Old Jan 17, 2015 | 07:20 AM
bswarm's Avatar
If the fluid level is OK, Auto trans morning sickness (not going into gear until the fluid warms up) are signs of hard or worn seals. If you do a fluid change it may help or make it worse, especially if it has over 100k miles.
Old Jan 17, 2015 | 09:55 AM
Well it was in a parking lot it been parked about an hour before I got back to so it shoulda been somewhat warm, yea it has 266,xxx miles so I'm sure it's getting wore out
Old Jan 17, 2015 | 12:18 PM
Ok fluid level is low. It's leaking behind the rear driveshaft flang, it wasn't leaking till it warmed up so I couldn't see it dripping on the ground when parked over night. I'll replace the gasket and refill and see how it acts and update
chuckross1957
Jun 28, 2019 10:19 PM
mskalmus
May 28, 2017 07:51 AM
mYnAmEiSmUd
Jul 20, 2015 06:48 AM
jjrbus
Jul 17, 2015 07:06 AM
Poncho0206
Jul 10, 2015 06:21 PM
