Engine Reving
Old Jan 15, 2015 | 04:35 AM
keithbrents's Avatar
Engine Reving
94 4x4 pickup with 228,xxx miles When stopped at a light or stop sign with my foot on brake, my engine revs up and down. Only when putting pressure on brake though. Any answers? Engine runs great was just curious why it does that and if I could do anything to fix it.
Old Jan 15, 2015 | 05:11 AM
Jake28296's Avatar
If it's just when the brake is applied you have it idling too high adjust it down and the surging should stop
89' pickup 4 inch rough country suspension 31x10.50 dick cepek fc2s 15x8 ion alloy 174 series wheels+ glenns over the rail dogbox,mega 4 tracking unit,cb and private band radio, 2 6x9 speakers and over 15 deer a year put on the back!
Old Jan 15, 2015 | 05:28 AM
Do you recommend that I adjust it or will it be fine if I leave it. It doesn't really bother me I was just worried that there was something wrong.
Old Jan 15, 2015 | 05:34 AM
Jake28296's Avatar
I'm not sure on that one I adjusted mine when it did it My problem now is it does that without the brake being applied
Old Jan 15, 2015 | 05:53 AM
Ok thanks brother
Old Jan 15, 2015 | 07:42 AM
bswarm's Avatar
If adjusting the idle doesn't help, check the brake vacuum booster and check valve.
Old Jan 21, 2015 | 04:33 PM
bootscootboogie's Avatar
Mines an 84 and its doing the same thing. From what I've gathered we got air in our brake system and vacuum leaks. I'm putting in a new brake booster and master cylinder to see if it stops.
icentropy
Sep 16, 2020 02:47 PM
RaginAsian91
Engine Swaps
Mar 30, 2019 09:17 AM
jasonty
41
Dec 23, 2018 01:00 PM
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
razorman8669
Jul 12, 2015 12:13 PM
