diesel swap
Old Mar 18, 2006 | 03:58 PM
tasthree's Avatar
diesel swap
Has anybody here actually performed a 1kz-te with a auto. swap into a 2nd gen. 4-runner with a 3.0 v6 and a auto tranny.If so what are the major obstacles.I'm a welder/machinest and a pretty good mechanic with many tools.I need concrete info no ors,ifs,ands and buts.
Old Mar 19, 2006 | 08:41 AM
hill's Avatar
id be curious about the exact same question..... but i have a manual....
Old Mar 19, 2006 | 09:38 AM
Quakefire's Avatar
From what i've seen there is a member who buys half trucks, everything from the shifter forward with the diesel and swaps those in. You would most likely need new mounts, and I believe you would need to flip the transfer case a 180 degrees because due to steering components the front diff is on the other side. Besides that you need to run new fuel lines, and I do mean all of them gas in a diesel engine, even just a little bit is a really bad thing, so that means fuel filters, pumps, prolly even the tank have to be replaced. You most likely will need custom drive shafts or the ones to fit a diesel 4runner. Plus things like wiring harness and ECU plus you need a new tach as a diesel redlines closer to 3500 rpm than the 6 or 7 the 3vze does. Now aside from all this, its a Toyota Diesel, the most sought after motor in all of north america, and the most durable of all toyota motors. This plus the gas milage makes the headache of the swap worth it.
And Hill how much do you know about hte 3VZ-E? I need to rebuild the core i'm going to buy and you just so happen to be in my neck of the woods, always glad to have someone I can ask questions of
Dan
Old Mar 19, 2006 | 11:41 AM
hill's Avatar
Dan, dont know tons about the 3VZ-E but there are some good toyota mechanic guys in calgary that i have talked to on www.ih8mud.com
Stay in touch.. im up in valley ridge.
Colin
tobylab
Jan 18, 2016 07:06 PM
RobotMoose
Diesel Swaps
Aug 2, 2015 11:00 PM
toyoterferdayz
Diesel Swaps
Jul 27, 2015 05:25 PM
Nailit69
Diesel Swaps
Jul 21, 2015 05:28 PM
tobylab
Jul 12, 2015 12:53 PM
