More T-bar questions
Old Mar 20, 2006 | 08:53 AM
RustBucket's Avatar
Just put new leaf springs in the rear - rebent with an added leaf. Probably picked up 3-4" of lift and I'm probably topping out my shocks too
I need to crank the T-bars a little to level it out and I need some help with that. I see the 22mm adjusting nut and the jamnut above it, but once I get the apparatus free, which way do I turn the adjuster to raise the ride height on the front? Also, I have heard a 1 1/2" increase is the most the stock t-bars should be subjected to, but how many turns of the adjuster bolt does this translate into?
Thanks!
Old Mar 20, 2006 | 11:12 AM
celica's Avatar
Righty tighty will raise the front, Lefty loosey will lower it. Number of turns depends on how much fatique the bars have. It is really a trial & error process. Don't forget to jack it up to do it & you will need to drive around the block to seat them t ofind out haw much lift you really have
Old Mar 20, 2006 | 12:09 PM
tc's Avatar
tc
You may want to get the bolts from your dealer before attempting to adjust them. Seems to be about 50/50 that you break one or both. Also, plenty of soaking in PB Blaster...
Old Mar 20, 2006 | 02:30 PM
RustBucket's Avatar
okay, thanks for the info. I guess I judged incorrectly when I started cranking lefty loosey on them to bring it up heh heh
So, just to ballpark, you think 8 full turns will bring it up an inch?
Old Mar 22, 2006 | 12:28 AM
smiljko's Avatar
Here - this might help
http://www.off-road.com/toyota/tech/torsion/index.htm
Old Mar 22, 2006 | 03:25 AM
celica's Avatar
Sounds about right
Old Mar 22, 2006 | 04:47 AM
RustBucket's Avatar
sweet, thank you.
lectric80
Aug 11, 2015 12:02 AM
makemusic116
Aug 2, 2015 05:23 PM
makemusic116
Aug 2, 2015 04:40 AM
TJWilly
Jul 31, 2015 02:05 PM
4Runnin2000
Jul 29, 2015 06:09 PM
