hub gaskets
Old Mar 21, 2006 | 09:55 PM
wailukutoy's Avatar
hub gaskets
I'm going to install man hubs on my truck, probably warns. In reading the conversion install, I noticed that the hubs only comes with one pair of gaskets(the star shaped one) to go under the hub covers. Do I not need the gaskets that go under the hub body like with the aisin hubs. The conversion write up doesn't specifically state the hub body mounting, and I was just wondering if I needed these other gaskets to put under the hub body for the Warn hub conv. or not. THanks for the help
Old Mar 22, 2006 | 04:57 AM
RustBucket's Avatar
I used some RTV sealer rather than gasket on my aisins.
Just curious - why Warns? Those are probably more than $150 and a set of aisins are like $40, and the guys around here will tell you that they rarely break.
Old Mar 22, 2006 | 09:12 AM
tc's Avatar
tc
I just used Ultra Copper RTV on my Warns. (I know, overkill on which RTV, but that's what I had handy)
I would go with Warn instead of Aisin because:
- You can get them new or very near new (my understanding is Aisin is available OEM only - have to buy them off someone who's truck came with them)
- More available
- Lifetime warranty
As for breakage - I want my hubs to break before anything else to protect the harder to replace components. Hub replacement is SUPER easy!
Old Mar 22, 2006 | 01:33 PM
RustBucket's Avatar
so you would pay more for a hub to have less integrity?
Old Mar 22, 2006 | 04:55 PM
tc's Avatar
tc
Not necessarily, but I would pay more for new than 15 yrs old.
Old Mar 22, 2006 | 05:53 PM
RustBucket's Avatar
good point
Old Mar 22, 2006 | 07:27 PM
wailukutoy's Avatar
Ok thanks guys, but if I were to use gaskets instead of silicone, do I really need the gasket that goes under the hub body?
Old Mar 23, 2006 | 05:49 AM
tc's Avatar
tc
You mean between the manual hub assembly and the hub/rotor assembly? I think you need something there to make sure it seals - last thing I want is water getting in there!
Old Mar 23, 2006 | 06:02 AM
BLKNBLU's Avatar
Too true. And Wailukutoy, I'm guessing that in HI you might have the possibility of sand as well. Seal it up.
Jcrawl94
10
Oct 24, 2015 04:34 PM
carlspeed
Aug 23, 2015 02:59 PM
Steven.m.paulk
Jul 24, 2015 01:44 PM
PlayAwhile
Jul 20, 2015 11:36 AM
Steven.m.paulk
Jul 13, 2015 01:40 PM
