dead v6 cylinders
Old Mar 21, 2006 | 03:10 PM
pullnshoot25's Avatar
dead v6 cylinders
Ok people, my brother and I ran a compression test on my 1989 V6 because of crappy gas mileage and lack of "ooompf!". Here are the readings on the cylinders.
FIREWALL
175 --- 75
25 --- 175
175 --- 160
FRONT OF TRUCK HERE!!!
The compression problem is also manifested in a repetetive tick from the passenger side wheel well (where the 25psi cylinder is). That particular cylinder also has a blackened spark plug (and I just replaced the spark plugs on the 20th!)
So what say you, fellow Yotatech members? What couldeth be the problem?
Old Mar 21, 2006 | 03:14 PM
ChickenLover's Avatar
Looks like worn rings or improperly seated valves.... Or you've managed to blow both HG's at the same time.
Old Mar 21, 2006 | 03:25 PM
regularguy412's Avatar
What ChickenLover sayeth. How manyeth mileseth on this lil puppy?
(Apologies to Bill Shakespeare)
Mike in AR
Old Mar 21, 2006 | 03:55 PM
just crossed 149k
we did a "wet" test on the 2 cylinders and they were not indicative of worn pistons... or something. So I am guessing headgaskets, which Toyota has already replaced once (I am the third owner, so I will ask the previous owner when it was done)
Old Mar 21, 2006 | 03:58 PM
Are there any other signs of a blown HG? Milkshake, green goo under oil cap, loss of coolant, lots o' steam out the tail pipe?
Old Mar 21, 2006 | 04:02 PM
bike4miles's Avatar
I think you can call the dealer to find the exact date of the HG recall work.
Old Mar 21, 2006 | 04:32 PM
no green goo, but there is a lot of white smoke and lots of water coming out as wel.
Old Mar 21, 2006 | 04:37 PM
superjoe83's Avatar
out of the exhaust? does it smell sweet?
Old Mar 21, 2006 | 07:10 PM
AcidicDreams's Avatar
ohh noes... I just bought a 95 4Runner with 150k miles and the dealer insisted I didn't wasn't eligable for a head gasket recall but I do get sweet smelling exhaust, mostly when cold but there is a small amount when warm... I haven't done a compression test though... were the above signs very indicative of a blown HG?
raptor510
Feb 17, 2017 07:11 AM
83
18
Sep 21, 2015 06:15 PM
Alex Bessinger
Aug 31, 2015 09:17 AM
raptor510
Aug 19, 2015 02:15 PM
Corey
Aug 24, 2009 07:53 AM
