changing gears and lockers
Old Mar 24, 2006 | 10:04 AM
shawnhog's Avatar
Here we are, on the verge of trying the hardest mechanical task I can do as of yet (after welding bumpers and dropping transmissions): ARB locker, quick-lock, and 4.88 gears.
I was price shopping around, and I found that most companies would charge about $3,000.00 for the whole thing, and I do not like that. I would rather spend 1,500-2,000 and do the work myself, so my question for y'all is this:
I have access to a very good shop with many specialty tools. What is the list of tools that is necessary for performing a gear swap?
I am tempted to keep it simple and not change the gears (currently 4.56) and instead drop in the Lock-Rights into the diff case. The 4.56 is geared for 31" tires, and my new tire size will be 33" tall tires. Should I leave the gears alone and drop in the Lock-Rights only?
Old Mar 24, 2006 | 10:58 AM
regularguy412's Avatar
You can probably get by with leaving the 4.56's in there,, especially if it's a manual tranny. It will have a lower 1st gear than an automatic.
I run 31's with an auto tranny and it gets around just fine. Any taller, tho, and you'd prolly want lower gears (higher numerically),, like 5.29's.
Mike in AR
Old Mar 24, 2006 | 01:03 PM
tc's Avatar
tc
I just did this - ARB's and 4.56->4.88
Why are you only doing one ARB? So many package deals for both lockers and the compressor, I can't imagine you saved much $ by going with the quick lock...anyways, I digress....LOL
4.88 is the right gear ratio for 33's with manual tranny (auto, I would consider 5.71 actually - the overdrive is so damn tall that you can get away with SUPER low gears). DEFINITELY do it while you're in there. You can get the gears set up for ~$200/axle if you drop the third members and take them into the shop.
The big problem I ran into was my master install kit came with the wrong size carrier bearing. The V6 rear has two different ones - my '93 had the larger 50mm one, and the master install kit came with the smaller one. The ARB manual has the Timken part number for the larger one, would be a good idea to have one of each on hand before the truck is taken apart.
Old Mar 24, 2006 | 01:07 PM
Jeffires's Avatar
If you do Lockrights, you really don't need special tools. At the time I did mine, I didn't even know what some of the tools were that I was told I needed to use. If you are somewhat mechanical, and you mark everything before you take it out, you'll be able to drop in Lockrights in an afternoon.
smthwsn357
May 1, 2024 07:28 AM
oldirtydirt
Feb 23, 2020 09:30 AM
jerusry
Oct 19, 2015 05:28 PM
Daneums
Aug 20, 2015 05:36 AM
wilbertd
Jul 6, 2015 07:39 AM
