3.0 problems
Old Mar 26, 2006 | 06:04 PM
big jim's Avatar
3.0 problems
Ok. I picked up an 88 runner sr5 3.0 with bad head gasket. i got another 3.0 from a friend who was parting out his 91 pickup. the engine has high miles but ran fine in his truck. I swaped this engine into my truck and it runs,kind of. it will start but it it runs very rough. it almost dies when i put the auto in gear and has even less power than a normal high milage 3.0. i checked the timing, checked for vacum leaks and i don't have any codes. what do you guys think the problem could be? thanks in advance for the help
Old Mar 26, 2006 | 06:06 PM
4runnermt's Avatar
Did you check all your ground straps?
Old Mar 26, 2006 | 06:19 PM
DarylD's Avatar
Injectors . Use the injectors from the 88 . The 88 has a different impedence from the rest of the 3.0 s
Old Mar 27, 2006 | 06:54 AM
big jim's Avatar
Thanks guys i did check all the grounds and I had to use the 88 injectors because the plugs are different i am now thinking mabey i have a vacum line hooked up wrong and the egr is staying open or mabey i have an injector that is sticking open. what do you think? oh and did i mention this this thing is a major P.I.T.A to work on. I swaped out my 22r in my last truck in about half a day by myself. this one took all weekend with another mechanic helping me one of the days.
Old Mar 27, 2006 | 07:05 AM
dwh91102's Avatar
do you have the air intake hooked up to the afm?
Old Mar 27, 2006 | 07:16 AM
big jim's Avatar
I'm not sure what that is but I probably have it hooked up
Old Mar 27, 2006 | 09:11 AM
dwh91102's Avatar
afm= Air Flow Meter
Old Mar 27, 2006 | 12:15 PM
big jim's Avatar
yea
Yea i got that hooked up. it wont run at all withuot that will it? any way I disconected the egr and pluged the hole and it pretty much run the same. any other clues?
Old Mar 28, 2006 | 08:23 PM
big jim's Avatar
Hey come on guy's I have an sas kit sitting in the garage that i'm dieing to put on but can't bring myself to do it until i get it running right. please help
Charecter1
Nov 6, 2023 10:08 AM
tobylab
Jan 18, 2016 07:06 PM
Alex Bessinger
Aug 31, 2015 09:17 AM
tobylab
Jul 12, 2015 12:53 PM
Coreyr384
Jul 10, 2015 11:13 AM
