ARGH body lift problems!!
Old Jul 22, 2006 | 02:13 PM
Kyle95sr5's Avatar
ARGH body lift problems!! Problems solved, Pictures of final product are up!!!
Im installin my WabFab body life on my 4runner and so far I have run into some purdy damn annoyin problems . Took me about 30 minutes to get the front bumper off due to some of the hardest to turn bolts ive ever came to in my life. After that ive finally started gettin to my body mount bolts. The first one i came to, the bolt head is startin to turn but the nut or bottom of the bolt is not therefore im bout to break it off. Should i just break it off or should i just stop while im ahead and "seek professional assistance". Theoretically if i break them, im gonna be replacing them anyway so its really no big deal, correct? Is this just my 4runner or were ur guys bolts this damn hard to turn as well. Sorry for the rantin but damn
Old Jul 22, 2006 | 02:23 PM
garrett1478's Avatar
have you tried using anything like PB Blaster or liquid wrench to loosen the bolts/nuts?
Old Jul 22, 2006 | 02:26 PM
Kyle95sr5's Avatar
ive given um a good soakin in liquid wrench but its not seem to be havin any effect.
Old Jul 22, 2006 | 02:45 PM
89macrunner's Avatar
heat em up!....my dad and i did the pads and rotors on my sister's 97 A4 and PB blaster did nothing...we broke out the torch and the heat helped break them loose
Old Jul 22, 2006 | 02:47 PM
Kyle95sr5's Avatar
i got a match...would that work? hahaha man i wish i had all the good tools. My tools are the bare essentials (ratchets, wrenches, sockets, duck tape). I aint got all the goodies. What do yall think of just breakin them off because i need to put the new bolts in it anyway. IS there any risk in doing this becasue i would really rather not seriously screw up my runner.
Old Jul 22, 2006 | 02:52 PM
rocket's Avatar
I basically had the same thing happen to one of my bolts. It bent and stripped so i ended up using a hacksaw and had to cut it in half. You can see my pics and install here.. https://www.yotatech.com/forums/f199/rockets-1992-4runner-build-up-thread-totaled-67410/
Old Jul 22, 2006 | 02:54 PM
Kyle95sr5's Avatar
alright so thats the motivation i needed. time to start breakin crap. ill let yall guys know whenever i totally screw somethin up. thanks rocket.
Old Jul 22, 2006 | 02:56 PM
dwh91102's Avatar
Do you have the plugs out of the floor, and holding the top of the bolt with a socket?
Old Jul 22, 2006 | 02:57 PM
waskillywabbit's Avatar
PB Blaster. Soak them at least overnight and try again perhaps or just break them off, cut them off...whatever. Make sure you replace the ones you remove elsewhere w/ OEM so they are coated. The ones on my 1st gen all came off easily after spraying them w/ PB Blaster the night before.
I was nervous to look at the thread when I first saw the thread...the first sentence is even kinda misleading if you don't read it right, but it isn't my body lift kit that is the problem...it's your stupid truck.
Good luck.
Old Jul 22, 2006 | 05:50 PM
Kyle95sr5's Avatar
alright come on guys i need some help. im half way through my body lift, everything is goin better then before. got all the bolts out/loose except one that is bent on the front drivers side. I have cut all that i can with the sawzaw and i cannot get the damn thing to budge at all. can someone plz come up with a picture of what the busing for the front drivers mount looks like so that i can see what else i can cut and what needs to stay. anyone got any other ideas
Old Jul 22, 2006 | 05:55 PM
Cut the head off the bolt then pull it out w/ some vice grips.
The bushing is inside both pieces of rubber as it is there to keep you from tightening things too much and crushing the rubber.
Old Jul 22, 2006 | 06:16 PM
rocket's Avatar
are you talking about the very front mount where the bumper goes?
Old Jul 22, 2006 | 06:40 PM
LOCKnGO's Avatar
Thats what I was wondering, If it's inside the cab cutting the head is damn near imposable
Go to your local hardware store and get a MAPP gas torch. 20.00 max heat that nut till it almost turns red and then spray PB on it let it sit for a few minutes then heat that bugger up again, it'll come loose! Watch out for the flare up you don't wan't to burn up yer rig/.
i used lots of heat and PB doing these
Old Jul 22, 2006 | 06:47 PM
I read that to be the front body mount. With the front bumper off you can access the top and bottom of that bolt pretty easily IIRC...at least on my 85 and 87.
Old Jul 22, 2006 | 07:20 PM
Kyle95sr5's Avatar
alright guys, thanks for all the help but i think i have purdy much gotten things buttoned up. I still need to try and figure out how to get the rest of that bushing out of the front drivers (the one right under the front bumper) but the rest of the body lift is done. I need a front bushing though because mine is cut to about 50 pieces in my yard and still part of it remains to piss me off. Do any of yall have a bushing for it used or new i dont care. I need one kinda like soon because there is no spacer or anything in there its just open. Id appreciate if yall had one lying artound or somethin. thanks for all the help guys.
Old Jul 22, 2006 | 07:29 PM
Kyle95sr5's Avatar
anyone got a front bushing that i could buy?
Old Jul 22, 2006 | 08:00 PM
LOCKnGO's Avatar
Sorry I used a torch when I installed my pretty red ES poly bushings.
Old Jul 22, 2006 | 08:09 PM
rocket's Avatar
I think i tossed mine in the trash but when i get home tonight i'll take a look and see if i still have them. If i do, it's yours for free + shipping.
Old Jul 22, 2006 | 08:11 PM
Kyle95sr5's Avatar
hmmmmmmm.....anyone else got one? I kinda need one bad and dont feel like buyin a whole kit just for one front one. thanks guys
lockngo- you and your fancy tools...blah.
Old Jul 22, 2006 | 08:14 PM
Kyle95sr5's Avatar
thanks rocket, id appreciate that. by the way, your truck is wut inspired me to build up my 4runner. some 33x10.50 BFG ATs are gonna be ordered as soon as my 31s wear out. its just a shame wut happened. if perhaps i couldnt get ahold of one for a lil while. would it hurt my 4runner NOT having the bushing and body lift in there. I assume over time it would but how bout for a couple days, maybe a week.
