air conditioning problem
Old Jul 23, 2006 | 12:13 PM
gomez3247's Avatar
Red face Air conditioning prtoblem
have a 94 toyota p/u, air works great, problem is when air is on and the break is applied the engine revs constantly up and down very fast and consistant. this cant be normal. what gives HELP!!!!!!!!!!! :pat:
Old Jul 23, 2006 | 12:17 PM
gomez3247's Avatar
have a 94 toyo p/u air works great, only problem is when air is on and the break is applied the engine revs up and down very quickly and, constantly, this cant be normal what gives HELP!!!!!
Old Jul 23, 2006 | 01:07 PM
seanz0rz's Avatar
Guest
bad compressor clutch?
would help to post what engine, etc,
not to mention in the right forum, wtf?
post in the approiate truck forum!
Old Jul 23, 2006 | 01:18 PM
trythis's Avatar
I rememebr reading that something about your idle being too high. WHen you hit the brake, it grabs vacuum, and the vacuum advance tries to raise the idle, bu tit is already too high, so it shuts it down, then brings it up, puts it down. I bet I am half right about this.
Try this thread at Toyota Nation http://www.toyotanation.com/forum/t113388.html
its very long, but youll know more than you wanted to about idel problems.
Old Jul 23, 2006 | 01:56 PM
oly884's Avatar
Guest
Um, wrong section man.
Old Jul 23, 2006 | 01:58 PM
all_terrain17's Avatar
I had that problem too. Adjust this greenish colored piece here:
It screws into the intake manifold between the E and the F. Twist the plastic screw on top clockwise with your fingers to lower the AC idle, but BE CAREFUL. I broke this screw before and it cost like $30 to replace.
If your having the same problem while applying the brakes, your idle speed is too high. To adjust that, turn the gold screw on the throttle body with a flathead screwdriver.
Old Jul 23, 2006 | 02:02 PM
Corey's Avatar
Co-Founder/Administrator
Thread moved out of "Site Feedback" to correct section.
Old Jul 26, 2006 | 05:26 PM
gomez3247's Avatar
i found the right forum no post or responce in 30 days .........................i aint got that kind of time .............. You only got time to say "get in the right forum .??? save your valuable time and dont bother responding at all. much less you dont even own a yota as you so elequently stated, so keep your NEG. responces to yourself.
Old Jul 26, 2006 | 07:23 PM
Saint_Berzerker's Avatar
I don't have any advice on this problem, except adjust that green knob like the guy above said....
...but DANG! didn't know there were such jerks on those other forums!
Old Jul 26, 2006 | 07:37 PM
workinprogress's Avatar
im having a similar problem with my 95 4runner, only mine wont idle up 99% of the time(when i turn on the air).sometimes it holds steady rpm,but most of the time it drops.is that the "idle up valve" you are suppost to adjust?
the1998sr5
15
Jul 14, 2020 08:35 PM
Eggslinger
Jun 8, 2019 03:32 PM
BeMiceElf
Oct 10, 2015 09:40 PM
Alex Bessinger
Aug 31, 2015 09:17 AM
karbin
Jul 5, 2015 11:37 PM
