Need quick distributer install help!
Old Jul 28, 2006 | 07:22 AM
shwuz's Avatar
I'm almost done with my headgasket/cam replacement, and I go to re-install my distributer, and my manual says to put it so the rotor is in the same position as when it came out... But I didn't pull the dist. cap before pulling it, just pulled out the whole distributer!
So, easy question for those who know... On a 22re, where should the rotor be pointing when installing the distributer, TDC.
Thanks!
Old Jul 28, 2006 | 07:24 AM
callmej75's Avatar
The motor should be rotated to TDC and rotor pointing towards #1 spark plug wire. Then insert..
Old Jul 28, 2006 | 07:36 AM
snap-on's Avatar
make shure your TDC on COMPRESSION stroke!
Old Jul 28, 2006 | 08:22 AM
shwuz's Avatar
That's what i thought, thanks.
And I'm pretty sure I'm on the right stroke, I turned that thing over and over trying to get my valves adjusted, but I'm sure I stopped on the right spot.
I think.
Old Jul 28, 2006 | 08:26 AM
shwuz's Avatar
ok, it won't go in right on top of #1 wire, either a little before or a little after. Which side to I want it on?
Old Jul 28, 2006 | 08:28 AM
95RunnerSR5's Avatar
pull the plug on your #1 cylinder and when you rotate the motor to TDC, stick your finger in the plug hole and you can feel when you are on the exhaust stroke because it will try to blow air out...same thing for the compression stroke, it will feel like its pulling around your finger
Old Jul 28, 2006 | 08:29 AM
shwuz's Avatar
lovely, I also don't have the VECI label under my hood that the manual is calling for.
Old Jul 28, 2006 | 08:54 AM
shwuz's Avatar
please, does anyone have the jumper locations for the 94 22re?
Old Jul 28, 2006 | 09:23 AM
crackerjack's Avatar
man I'm shufflin through my shop my label just points with little arrows leftside row closest to engine allthe way to the right the second row middle hope this helps
Old Jul 28, 2006 | 09:49 AM
eric-the-red's Avatar
You want it a little before, so the plug fires before tdc.
Old Jul 28, 2006 | 10:04 AM
TNRabbit's Avatar
try this link: http://www.off-road.com/toyota/tech/codes/index.html
Old Jul 28, 2006 | 12:15 PM
shwuz's Avatar
Thanks tnrabbit! Ok, stupid question, but I must ask. The terminals to jump for getting codes are the same ones to jump for setting the timing, right?
I did actually get it started, since there are waves and I wasn't going to wait around to get it perfectly timed before heading to the beach. Even though I didn't note the position of the rotor, I was smart enough to mark the housing of the distributer and the head before pulling it, so I had a place to start for timing. The only change I made was advancing it about 1/8" (per the mark on the distributer), and it seemed to run great that way.
The engnbldr cam is nice, subtle, but it definitely takes the flat spot out of the powerband from 2k to 3.5k. Just hope the HG holds up!
Thanks again for the help, I certainly couldn't have done this whole thing without this forum!
Old Jul 28, 2006 | 01:22 PM
ovrrdrive's Avatar
That's the hood sticker off my 95...
krimsonone
Sep 13, 2024 09:33 AM
nvdesertrunner
May 11, 2020 08:18 PM
jasonty
41
Dec 23, 2018 01:00 PM
Esibnitsud
Jul 30, 2015 08:19 PM
HookahRoo
Jul 20, 2015 07:06 PM
