Catalytic removal
Old Jul 28, 2006 | 04:13 AM
psychobillyman's Avatar
Catalytic removal
Hi,
I’ve got a quick question. I’ve got a 1988 4runner and think my cat might be plugged up, so I was just curious if I could just remove it. I have never removed a cat from an EFI engine; I figure it should be fine, just wanted to know for sure.
Thanks,
Jake
Old Jul 28, 2006 | 04:16 AM
AH64ID's Avatar
Yes you can, but you will find (search and see) that most people dont like their cats gone. I did mine and all it did was stink, horribly. IMO get a carsound (magnaflow) replacment...
but to answer your original question, it wont affect your EFI at all.
Old Jul 28, 2006 | 06:01 AM
brandontrek's Avatar
running a straight pipe is just annoying...i think you get a much better sound and smell out of a magnaflow highflow. if your in the market hit up cootees with a pm. he hooked me up with one in 2 days....
Old Jul 28, 2006 | 06:49 AM
trythis's Avatar
Please don't run without a converter. That stuff up there , in the air that causes athsma, etc. (smog) is caused by the crap coming out of YOUR (and my) exhaust. Running without a catalytic converter is like driving 20 cars from the 1970s. We all make polution, why add to it unecessarily. That whole tread lightly bit includes the air.
Sorry for the rant, but there it is.
Old Jul 28, 2006 | 06:53 AM
Churnd's Avatar
It affected mine. I suspect it caused the 02 sensor to report faulty readings, therefore causing my idle to fluctuate between normal and lower than normal. Sometimes I thought the engine was gonna die. I put a Carsound cat on, and it fixed the idle issue, and I noticed no performance loss from it. I actually gained some low end torque without sacrificing high end HP.
Plus, it's horrible for the environment. Don't hack it off.
Old Jul 28, 2006 | 06:57 AM
Bumpin' Yota's Avatar
Well the O2 sensor is actually upstream of the cat so it shouldnt alter the readings of it... Im willing to bet the idle issues were propagated by the lack of backpressure, turning up the idle probably would have helped. But I agree on a NA gasser id leave the cats. Now a turbocharged application would be a whole different ballgame!
Old Jul 28, 2006 | 07:02 AM
Churnd's Avatar
Right, but it's pretty close and takes a 360* reading, so I'm sure the lack of backpressure (read, exhaust gas) had some effect on it's reading.
Old Jul 28, 2006 | 07:15 AM
DirtCheap's Avatar
No, it does not affect the O2 sensor.
Old Jul 28, 2006 | 07:48 AM
whitetaco02's Avatar
where can i get a carsound cat at? I am very interested and what kind of price am i looking at?
Old Jul 28, 2006 | 08:02 AM
DirtCheap's Avatar
You can buy a comparable replacement cat at any local muffler shop, ie.. Midas, Mieneke, etc. The O2 sensor is not in the loop at idle.
Old Jul 28, 2006 | 08:23 AM
maxpower_hd's Avatar
I bought a chepo cat at advanced auto for about $99. It was a direct fit and works fine. I could not pass inspection with my old one ewven though it still performed fine.
Old Jul 28, 2006 | 09:03 AM
Tdubbs05's Avatar
i don't mean to be liberal ( b/c i sure as hell am not) but i'd have to agree that its time to actually start thinking about pollution control. after living in the bay area, ca for the past 19 yrs, the smog has definitely gotten more and more noticable. before now i always thought it was such trash how ca smogs cars, but now i realize it's a good thing...
Old Jul 28, 2006 | 10:30 AM
Elton's Avatar
Carsound 14'' $62 shiped Carsound 16'' $67 shiped .... i took off my cat on my 22re and it didint do nothing but make it a little louder plus you can get a ticket for not haveing one
Old Jul 28, 2006 | 10:35 AM
X-AWDriver's Avatar
I ran my turbo Eclipse cat-free for performance reasons but on a NA engine the gains are so insignificant it's not worth the trouble of adding pollution;my Eclipse also only saw about 5000 miles a year and was primarily a track car.
Old Jul 28, 2006 | 02:04 PM
tampabayota's Avatar
so you shouldnt run without a cat on a turbo?
Old Jul 28, 2006 | 02:06 PM
Churnd's Avatar
Shouldn't run without a cat on a fuel injected engine period.
Old Jul 28, 2006 | 02:27 PM
Technically and legally you have to have a cat.
But with a turbo you cannot reduce backpressure post turbine enough! Lowering backpressure behind that turbine severely lowers EGTs which help save yer engine. If I do turbo my yota ill be pulling the cat or getting a huge arse cat that will provide zero restriction. Until then im keeping my carsound Hi Flow cat!
Old Jul 28, 2006 | 03:40 PM
rimpainter.com's Avatar
That's true, but information needs to be added. The 5VZ has two sensors; one before the cat, and one after. Chris' idle probably got jacked up because the second "sniffer" saw much lower EGT's, therefore the signal back to the ECU was whacked out (my theory anyway).
I agree with others, it is best to run a cat on a daily-driven vehicle. Carsound is the way to go.
LotOMiles
Sep 14, 2015 11:45 PM
Rickstwowheels
Sep 9, 2015 06:12 PM
FJtoyman
Sep 8, 2015 04:47 AM
gp66
Sep 7, 2015 08:29 AM
AkitaDog
Sep 3, 2015 09:01 PM
