Bad Injector?
Old Jul 14, 2006 | 10:01 AM
ramrugby09's Avatar
Bad Injector?
Hey guys. Does anybody know how to tell if I have a bad injector? I have a very rough idle problem right now. I checked the tps, checked my timing and made sure my idle was correct. I pulled each spark plug wire to check for spark, all of them spark but when I pull the third plug wire the idle did not change at all. When I pulled the rest the truck almost cut off. Then I checked the connections for each injector they are all broken but are connected. I took off the one from the third cylinder and cleaned it then put it back. Still no change, so i disconected while the truck was running, it didn't make a difference. Is there anyway to make sure its the injector? Also to pull the injectors how should I do it? Is there a write up? Thanks guys!
Old Jul 14, 2006 | 10:08 AM
4Hummer's Avatar
Engine Type may help greatly
Old Jul 14, 2006 | 10:24 AM
ramrugby09's Avatar
sorry, its a 22re 1986 4runner
Old Jul 14, 2006 | 10:36 AM
4Hummer's Avatar
You can ghetto test them by adding 12Volts across the terminals and seeing if you hear them CLICK this wont tell you the spray patern tho.
You are best off taking them out and have them flow tested and cleaned.
Old Jul 14, 2006 | 11:19 AM
ramrugby09's Avatar
Are they easy to take out? Is there a write up?
Old Jul 14, 2006 | 12:29 PM
4Hummer's Avatar
Remove Upper intake, Remove fuel rail. REPLACE the O-Ring and gasket on the bottom of the injectors when you replace them
Best pick I have Look for the red connectors
Old Jul 14, 2006 | 12:52 PM
4Hummer's Avatar
I can post better pics tonight if you need as my motor is on an engine stand right now
Old Jul 14, 2006 | 01:38 PM
ramrugby09's Avatar
Thats ok...I think I can do it, thanks for the help. I'll let you know how it goes!
Old Jul 14, 2006 | 01:53 PM
4runnerx3's Avatar
4hummer is right. Mine was missing on #4, it was the o ring on the injector. I found it by sraying carb cleaner on the bottom of the injector and it smoothed off for a couple of seconds. I would change all four while you had it apart.
Old Jul 14, 2006 | 08:36 PM
toyfreak's Avatar
you can swap the injectors and if the problem moves with the injector than is either clogged or bad.
Old Jul 17, 2006 | 07:51 AM
ramrugby09's Avatar
Ok i bought a new/ remaned injector. I pulled everything apart and have installed it. I put everything back together and it did not seem to help. I still think I am not getting fuel to the third cylinder. Is it possible to not get enough fuel to only the third injector? Is there a way to test the wires that are going to the 3rd injector to see if the proper signal is getting there? Could the rail be clogged?
Old Jul 17, 2006 | 08:20 AM
TNRabbit's Avatar
I think a compression test of #3 is in order.
Old Jul 17, 2006 | 08:23 AM
spirtlanimilbus's Avatar
x2
check valve lash also
Old Jul 17, 2006 | 08:30 AM
ramrugby09's Avatar
Well I'll check the compression and valve lash that seems to be the only things left. But I really hope not because this motor is a jasper I put in less than 15k ago. Thanks guys I'll post my findings...
Old Jul 17, 2006 | 09:32 AM
TNRabbit's Avatar
Man, that is one PRETTY engine posted above!
Old Jul 17, 2006 | 01:53 PM
ramrugby09's Avatar
ok, I checked the compression and it is right below 180 like 178. So that is fine any other suggestions? With the engine running I pulled the #1 plug wire and let it run for 30 seconds, I then turned the truck off. I pulled the first plug and it was clearly wet. I did this same procedure with the 3rd cylinder and the plug was dry. Also when the truck idles in park you can tell it is missing but only slightly. When in drive it misses severly, you can feel the truck jerking.???????
Old Jul 17, 2006 | 02:16 PM
Chuki's Avatar
Stuck a voltmeter to the injector harness connector, you should get I think about 12volts to it, if not then you know where problem is.
Old Jul 17, 2006 | 02:33 PM
04 Rocko Taco's Avatar
you said you pulled the third plug wire and nothing changed, are you getting sprak to the 3rd wire? hold it near the engine and see if it arcs, or get a buddy to hold it....if you can find one dumb enough. lol.
Old Jul 17, 2006 | 02:34 PM
ramrugby09's Avatar
hmmm......just checked the connector harness and it reads right around 13 volts....
Old Jul 17, 2006 | 02:35 PM
ramrugby09's Avatar
04 Rocko Taco... yeah I've got spark ...
