"Spanner" Tool
Old Jul 24, 2006 | 07:14 AM
RustBucket's Avatar
"Spanner" Tool
Putting in a new rear 3rd member and I gotta torque down the spanner rings to load the bearings. Does Toyota sell a special tool for this? Or should I just fab one?
Old Jul 24, 2006 | 11:44 AM
RustBucket's Avatar
No one knows??
Fine... I'll just PM Zuk...
Old Jul 24, 2006 | 12:14 PM
mt_goat's Avatar
Zuk will know, seek out Zuk and you will find the answer: http://www.gearinstalls.com/
Old Jul 24, 2006 | 12:57 PM
Chuki's Avatar
If I'm thinking correctly your talking about the threaded rings that have the slots in them all over? The shop that set mine up just used a hammer and a brass drift.
I could be thinkin the wrong thing though.
Old Jul 24, 2006 | 01:20 PM
RustBucket's Avatar
Yeah that's the thing... I don't like the idea of tightening it with impulse force however...
Old Jul 24, 2006 | 02:03 PM
Chuki's Avatar
The guy that did mine is the only one in the area I live in anyone will trust with differentials or any kind of gearing, setup, etc...
Didn't bother me he did it that way. Your not torque'n the rings to specific ft-lbs, your just tightning them up until you get the correct amount of preload.
Old Jul 24, 2006 | 02:13 PM
86Original's Avatar
Zuk built his own "spanner tool". See his web site listed above, and you'll see he actually built a couple.
Old Jul 24, 2006 | 02:23 PM
ZUK's Avatar
ZUK
I did a google and couldn't seem to find a heavy duty spanner tool so I pm'd RustBucket and recommended he just make a fast one from the info shown about 3/4 down this link
http://gearinstalls.com/autopsy.htm
RustBucket--if you can't weld the bolt head in place then thread the hole and just tight the bolt down.
86Original---I see in your sig that you "removed the napo coil"....got new leafs?
ZUK
Old Jul 24, 2006 | 03:57 PM
86Original's Avatar
ZUK
When I wheeled Blanca, it seemed like I wasn't getting the compression out of the coils that I wanted. Took them off and am experimenting the with newer (& longer) AirLift RideControl bags. Have a feeling that I'll be getting some new leaves before next spring.
Old Jul 24, 2006 | 05:16 PM
RustBucket's Avatar
Yeah I'm just gonna weld a 1/2" socket in there rather than a bolt head. I've got welding class tomorrow evening so I'll make that along with a tool for taking off the pinion bolt and something to hold the crankshaft on the 22re we've got on a stand to get off a stubborn crank bolt.
jb451
7
Oct 7, 2022 06:58 AM
RobotMoose
Feb 22, 2020 07:44 AM
Scottcrb
Mar 3, 2016 11:57 AM
fabing455
Sep 7, 2015 08:08 AM
