Can't get Injecter's to fire.
Old Jul 19, 2006 | 05:12 PM
Adams90Toyota's Avatar
Hey...I am haveing some more problems with my 1990 22RE Toyota Pickup. I cant get the injecter's to fire, I have replaced the ECM, checked the EFI relay (It workes because i went and got a new one), I also checked the Circuit Opening Relay( it's good to). If you have any ideas on what I should do next I would like to here them...Thanks
Old Jul 19, 2006 | 05:57 PM
4Hummer's Avatar
Check your ground from the back of the head to the firewall, Most things on the 22re are Ground switched So if the engine isn't grounded right you get all kinds of problems
Old Jul 20, 2006 | 07:03 AM
I looked at that its good....Any other ideas?
Old Jul 20, 2006 | 07:19 AM
4Hummer's Avatar
Do you have Voltage to the connectors? Pull the coil wire off, stick your multimeter into the connector and have someone crank it.
Old Jul 20, 2006 | 08:42 AM
I got 12 Volts on both sides of the connector. Also removed wiring from ECM and had 12 volts coming out of ECM for injecter pulse wire.
Old Jul 21, 2006 | 07:56 PM
Anyone got a idea?????
Old Jul 21, 2006 | 08:03 PM
yota_krazy's Avatar
its my understanding that if you have voltage on both sides of a connector then you either have a bad switch or a bad ground. Go do some more checking! Get an electrical troubleshooting manual if you can to look at the wire diagrams. Good luck!
Old Jul 23, 2006 | 04:28 AM
Flash319's Avatar
Distributor pickup is probebly shot. That is what times the injectors. If you pull the distributor and turn it by hand, with the key turned on, the injectors will fire.
Old Jul 24, 2006 | 10:32 AM
Ok...Just put a New Distributor pickup on it b/c it was reading wrong on the meter, but bad news still want start...any more ideas and by the way thanks for all the help never would have gotten this far...
Old Jul 24, 2006 | 10:56 AM
toyaholic's Avatar
i just finished rebuilding my engine and on my first few attempts to start it i flooded the cylinders with the afm unplugged. once i plugged it back up and checked everything else it still wouldn't even cough. i pulled the plugs and turned the engine over a few times with the ignition and let it air out and when i put the plugs back in it fired right up. just a thought and something simple to try. also, when checking the backside of the computer leave it plugged in. i have a fsm with some great trouble shooting. it helped me get mine running.
Alexdosdall
Dec 10, 2017 05:48 PM
wberry85
May 17, 2016 05:45 PM
bradahman
Oct 1, 2015 09:24 AM
sonorn67
Sep 19, 2015 05:39 PM
Cwolfe
Sep 12, 2015 12:23 PM
