3.0 V6 problems
Old Jul 23, 2006 | 07:50 PM
workinprogress's Avatar
Unhappy 3.0 V6 problems
I have a 95 4runner with a 3.0,that has had a 'miss' in it since i got it.it runs great until i rev it up to about 2,500 rpm. then starts the trouble.it starts to spit and sputter.I have tested,replaced,and tried everything i can think of.But i have had no luck getting rid of the 'miss'.Am i missing something instead of the engine?Any advice would be greatly apprieciated.send me an email to mfrench95@yahoo.com thanks
Old Jul 23, 2006 | 07:53 PM
Elton's Avatar
could be the sparkplugs and wires or the AFM sensor maybe its the fuel filter or the o2 sensor there just alot of things that could cause it ..... welcome to yotatech im sure if you search you may find your answer
Old Jul 23, 2006 | 08:04 PM
ChickenLover's Avatar
Give us a list of what you've done. So we can get a better idea of potential culprits.
Old Jul 23, 2006 | 08:33 PM
Unhappy
here is what i have done so far:changed plugs,wires,cap,rotor,air filter,fuel filter,Cat,muffler,coil.i have also tested and corrected(where needed) timing,idle speed,EGR operation,ECU,TPS,ignition control mod.,engine vaccum and back pressure,and cleaned throttle body.also,im not sure(this is the only 3.0 i have driven)but it feels like it has a governor on it,like it is restricted.i am lost.where should i go next?
Old Jul 23, 2006 | 09:05 PM
Red3.slow's Avatar
ignition control mod? What did you mod? Sounds like it might be an o2 sensor, maybe.
Old Jul 23, 2006 | 09:09 PM
Well, the only other things I can think of:
A problem with the AFM (perhaps a restricted flap), or a problem with the fuel delivery system (injectors or fuel pressure regulator).
Old Jul 23, 2006 | 09:18 PM
i meant,ignition control module(oops).wouldnt the oxygen sensor set a code?
Old Jul 23, 2006 | 09:42 PM
95RunnerSR5's Avatar
yes it would throw a few since it is linked to a couple of systems...mine did anyways
Old Jul 24, 2006 | 06:46 AM
even though it looks like the original,I dont have any codes showing up so i guess the o2 sensor is out.how should i go about cleaning the AFM?will it hurt it to spray throttle body cleaner around the flapper door?or better yet,how should i test it?
Old Jul 24, 2006 | 06:48 AM
use electrical parts cleaner
Old Jul 24, 2006 | 06:57 AM
thanks.i will give it a shot.
Old Jul 24, 2006 | 07:02 AM
TNRabbit's Avatar
CAUTION CAUTION CAUTION!
DO NOT USE ELECTRICAL PARTS CLEANER!
Use ELECTRONIC cleaner (available from Radio Shack). Electrical cleaner will dissolve any plastic parts it comes in contact with. I know with from experience....don't ask! You can also use TB cleaner; I've done it with no problems. Read the container to be certain before you use it!!!
Old Jul 24, 2006 | 07:20 AM
thank you rabbit its too early lol i did mean electronic cleaner ah....
Old Jul 24, 2006 | 08:08 AM
kmcc78240's Avatar
so where to you spray the TB cleaner. Any pics?
Old Jul 24, 2006 | 08:45 AM
TNRabbit's Avatar
open up your VAFM box, take out the air filter, crank up the engine. While a buddy keeps the revs up to prevent it dying, spray cleaner directly into the intake in the VAFM.
I would FIRST remove the intake tubes & clean thoroughly inside to prevent running all that crap down your intake manifold.
Old Jul 24, 2006 | 09:18 AM
kmcc78240's Avatar
Thanks rabbit
Old Jul 26, 2006 | 09:05 AM
kmcc78240's Avatar
quick question
I was about to clean the AFM in my 95 4runner, 3.0 3vze. Should I clean the Throttle body before I spray the cleaner in the air box for the AFM?
Old Aug 2, 2006 | 01:31 PM
kmcc78240's Avatar
And If I where to clean The TB do I need to remove it first
Old Aug 2, 2006 | 05:47 PM
Bumpin' Yota's Avatar
Have you done any work on the timing belt? Ill betcha it skipped a tooth...
Or you have corrosion on one of the electrical connections ill bet...pull the plugs one by one with the engine running. You'll know if the plug is getting spark when ya do!
Old Aug 2, 2006 | 05:58 PM
TNRabbit's Avatar
I started a thread a few days ago that shows some of the stuff involved in taking off the TB & plenum; it is NASTY INSIDE! If you're going to do it, you might as well take it all the way down to the intake manifold because I guarantee you the plenum is filled with black gunk from the PCV hoses. I would read up REALLY WELL all the threads on here about removing the top end or you will invariably screw something up (TPS in particular, it is also easy to break off a small vacuum attachment under the plenum if you're not careful. When I removed my plenum I found one of the intake manifold bolts was backed almost all the way out! Funny, because the truck was running pretty darned good when I started on it!
