How do you tell if intake gasket isleaking?
Old Jul 21, 2006 | 08:04 PM
jjenks0's Avatar
I had to take my plentium off my 3.0 to fix a valve cover gasket. I did not replace the intake gasket. I just put on rebuit heads so it has not been on there that long. It is running rough so I am wondering if it is the intake gasket?
Old Jul 21, 2006 | 08:18 PM
reggie 00's Avatar
An old trick i have used in the past is to spray carb cleaner around the questionable surface. If the idle goes up at any point of the spraying, you gots a leak son.
Just make sure you dont do like i did the first time and accidently spray to close to the carb throat and the overspray cause the idle to rise. Spent quite a few minutes tring to find the leak again.
Old Jul 23, 2006 | 05:52 AM
jjenks0's Avatar
I bought some starter fluid yesterday so I will try that.
Thanks
wafoogalla
Nov 2, 2016 11:02 AM
Dakotaneu
Aug 15, 2015 07:24 AM
Koolbananass
Aug 12, 2015 01:59 AM
87blyota
Jul 10, 2015 04:31 AM
