Looking for bolts
Old May 23, 2007 | 05:20 PM
gametom's Avatar
Looking for bolts
ok so i have some broken bolts on the underside of my runner and i was wondering if anybody new what type of thread they where and where to get replacement ones and longer ones
this it the one of the bolts that holds the tow hook in place
This one is for the tow loop thing on the other side of the truck
And this is the skid plate bolt for this one i need to get a tap as well
Thanks
Old May 23, 2007 | 05:51 PM
weakyota91's Avatar
All three are a 1.25mm thread pitch. As far as lenghth goes the tow hook bolts are a 17mm head and 2/1/2 inches long, skid plate is also 1.25mm thread pitch and only 3/4 inch long. both hook and loop bolts are same length. Hope this helps
Old May 23, 2007 | 05:53 PM
gametom's Avatar
how are the diameters measured is it standard or metric
Old May 23, 2007 | 05:57 PM
weakyota91's Avatar
METRIC. definetly metric. standard bolds have a differnt thread pitch. Almost every bolt on a toyota pickup is fine thread (1.25mm). Unless u rethread to a standard u will totally goober up the bolt holes if u try to put a standard bolt in a metric size hole. My metric tap and die set had been very handy to me on my truck.
Old May 23, 2007 | 06:54 PM
curtiswyant's Avatar
Take the old ones with you to the hardware store and match 'em up?
Old May 23, 2007 | 07:41 PM
MudHippy's Avatar
Works every time.
The bolts may have a larger head, always in my experience. Use a grinder to make the head of the bolt the size you want. Or use the next largest size socket (14mm becomes 17mm etc.)
Old May 23, 2007 | 08:08 PM
tc's Avatar
tc
17mm head = M12-1.25xlength(mm) There are MANY bolts this size on your truck, get several spares.
Note that you need Grade 10 (or 10.9) in metric - NOT Grade 8 (or 8.8)! I doubt your local harware store will have them - I've always had to order them from Fastenal.
Old May 23, 2007 | 08:37 PM
weakyota91's Avatar
Ace hardware has NEVER failed me. atleast the one in redding here.
Old May 23, 2007 | 10:17 PM
gametom's Avatar
Thanks
some drunk guy
Aug 3, 2021 06:09 PM
Zach_trun
Jan 22, 2020 04:42 PM
mistershmi
Jan 5, 2016 11:07 AM
JUICE222
Oct 13, 2015 08:50 AM
JookUpVandetti
Sep 24, 2015 08:56 AM
